Weird sound from front end around 60 and up mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Nov 10, 2009.
  1. Nov 10, 2009 at 11:46 AM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    This has been going on for a while now but im just nervous because I dont know what it could be. Once I hit about 60 mph I hear this weird squeaking/high friction sound. Sorry I can not explain the sound any better than that. But I have no idea what this sound can be. I have a 2007 regular cab 4x4 with 30,000 miles on it. Has anyone had this problem before or know what it could be.
    Thanks Mike
  2. Nov 10, 2009 at 11:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    Pulley, bad belt, wheel bearing, brakes, :notsure: ?
  3. Nov 10, 2009 at 11:49 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Wheel bearings or your brake pads are loose. Probably your brake pad springs are loose, rubbing on the rotors??
  4. Nov 10, 2009 at 11:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Left or Right Side?? Change pitch with speed above 60??
    Just don't go faster than 60...problem FIXED!!
  5. Nov 10, 2009 at 11:50 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Nov 10, 2009 at 11:51 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    windshield strip:notsure:heard about that on here before.
  7. Nov 10, 2009 at 12:01 PM
    MikeyD
    Sayreville NJ
    Its not a constant sound. It will go for a second stop for a second go for a second stop for a second. Do you guys think i should bring it to the dealership just to check out. The warranty goes up to 36K correct?
  8. Nov 10, 2009 at 12:02 PM
    MikeyD
    Sayreville NJ
    And i cant tell if its coming from a specific side. And the pitch of the sound might get a little higher when as I go faster above 60 mph.
  9. Nov 10, 2009 at 12:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes it does and it sure wouldn't hurt.
  10. Nov 10, 2009 at 12:05 PM
    rdwarrior
    rdwarrior Well-Known Member
    Dirty, NJ
    pop and lock 5300, awaiting revenge fab sliders, leer topper, custom camping platform for bed
    if it sounds like nails on a chalkboard it could be your window cowling.
  11. Nov 10, 2009 at 12:10 PM
    MikeyD
    Sayreville NJ
    it does sound like nails on a chalk board! But it sounds like its coming from my front end not my windsheild. But that may be the problem im going for a spin in a little bit and listen a little more closely a see if it is.
  12. Nov 10, 2009 at 1:33 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    Well there IS a windshield TSB for a high pitched squeaky noise at high speed :p
    Some people around here described it like slowly letting air out of a balloon to get that squeaky sound.
  13. Nov 10, 2009 at 1:47 PM
    MikeyD
    Sayreville NJ
    then i dont think that is it. The sound sounds like high friction metal rubbing. almost like a grinding sound but squeeky.
  14. Nov 10, 2009 at 1:59 PM
    SubZombie
    South East
    2019 Voodoo TRD Pro
    If it really is in the engine bay it could be a number of things you're not going to get a for sure answer unless you take it somewhere... imo anyway.
    I'd say take it somewhere asap too before something really messes up.
    Also you might could test to see if it is the windshield thing anyway by pushing out on the windshield in different areas when you hear it and see if it affects the noise any.
  15. Nov 10, 2009 at 2:08 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I think it's a defective pulley or a worn belt.
  16. Nov 10, 2009 at 2:12 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check your front brake pad squealers first.
  17. Nov 12, 2009 at 12:05 PM
    MikeyD
    Sayreville NJ
    So I brought my truck to the stealership and go for a test ride with a tech. and the sound was not there. I was so mad. Now i probably have to go back tomorrow when i start hearing the sound again. And he was giving me shit about running bigger tires.
