weird sound in my tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eli8386, Feb 8, 2016.
  1. Feb 8, 2016 at 5:05 PM
    eli8386
    eli8386 [OP] Member
    eli
    2007 tacoma access cab
    Idk why my tacoma has a weird clicking sound when I go on reverse but it just started to make the sound when I also drive foward not as loud as when I'm going in reverse what can it be?
  2. Feb 8, 2016 at 5:17 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    First check that there are no rocks, nails, screws or anything else in the treads, then check u-joints.
  3. Feb 8, 2016 at 5:18 PM
    eli8386
    eli8386 [OP] Member
    eli
    U joints what is that? Sorry I don't really know much about it
  4. Feb 8, 2016 at 6:48 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    U-joints are at each end of the driveshaft which allows the shaft to move with the suspension and allows for the difference between transfer case and axles.
  5. Feb 8, 2016 at 8:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Universal Joints would be my guess also.
    OP have you ever greased the universal joints?
    Have you had any vibration when accelerating?
  6. Feb 8, 2016 at 9:01 PM
    eli8386
    eli8386 [OP] Member
    eli
    Yes Jimmy but also if I'm going downhill and it's in neutral it's also making the clicking sound
  7. Feb 8, 2016 at 9:10 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well the drive shaft will still be turning in neutral.
  8. Feb 9, 2016 at 5:42 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I know this comes up a lot. I've been meaning to get under my 2WD '15 PreRunner V6 and look for zerks, but have read the 2WDs do not have them.
    I would do it, but one of my knees is banged up.
  9. Feb 9, 2016 at 3:04 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would say the only true way to know is to look. My 2012 Prerunner does have zerk fittiings.
  10. Feb 12, 2016 at 6:07 PM
    mechanica
    mechanica Member
    Phoenix, AZ
    2011 DCSB PreRunner SR5
    My 2011 V6 Prerunner does not have zerks.
  11. Feb 12, 2016 at 6:09 PM
    Jrozz
    Jrozz Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    where do you live?
  12. Feb 12, 2016 at 6:11 PM
    eli8386
    eli8386 [OP] Member
    eli
    El paso tx
  13. Feb 12, 2016 at 6:12 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    Not much snow there haha. sometime ice can rely get lodged and screw things up.
  14. Feb 12, 2016 at 6:24 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    is your taco a prerunner? like others have mentioned, u joints on the 05-11's are sealed and go out fast.
  15. Feb 12, 2016 at 6:36 PM
    eli8386
    eli8386 [OP] Member
    eli
    It's not a prerunner it's the trd sport 4x4
  16. Feb 12, 2016 at 6:38 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    non the less you should check them and grease them
  17. Feb 12, 2016 at 7:04 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    Does it happen when you touch the brakes for the first time after switching from drive to reverse or vise versa?
    skiergd011013 likes this.
  18. Feb 12, 2016 at 7:10 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    does for me!!
  19. Feb 12, 2016 at 7:15 PM
    Rsoxfan1
    Mass
    Typically it's just the brake pads moving in the caliper when you first touch the brakes for the first time after changing directions.
  20. Feb 12, 2016 at 8:14 PM
    eli8386
    eli8386 [OP] Member
    eli
    When I accelerate up on till 35 but also when Ibrake no matter how fast in going
