Weird Sound Left Front Tire
Discussion in 'Technical Chat' started by grubburg, May 15, 2017.
  1. May 15, 2017 at 11:35 AM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    When backing up and when the left front tire is pointed right (inward), I get a weird pop/crack sound. It doesn't happen much, but it's concerning when it does.
    I put bilstein 5100's up front 1.75'' and then got an adjustment. That was probably 20k ago... Also running 265/70/17's. There isn't any rubbing. Everything looks fine. Can't figure it out... Don't see any signs of problems when I visually inspect it.
    ChadsPride likes this.
  2. May 15, 2017 at 11:44 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Try to tighten up the LCA cam tab bolts
  3. May 15, 2017 at 11:46 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Do you have aftermarket uca?
  4. May 15, 2017 at 12:13 PM
    grubburg
    2019 TRD OR MT
    stock uca
  5. May 15, 2017 at 12:15 PM
    ChadsPride
    This fixed my clunk, good luck OP.
  6. May 15, 2017 at 12:30 PM
    grubburg
    2019 TRD OR MT
    ahhhh. let me try it tonight. I torque'd to spec, but who knows what they did after adjustment...
  7. May 15, 2017 at 12:31 PM
    ChadsPride
    Yeah, lot of time the alignment guys won't wrench em down.
  8. May 15, 2017 at 3:38 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yup it's a typical problem. When I had a clunk and went to do mine I found them all seized. All freaking 4 of them and so I had to cut them all out and replace. Shitty job
    grubburg[OP] and ChadsPride like this.
  9. May 15, 2017 at 4:06 PM
    grubburg
    2019 TRD OR MT
    LOL that's a ball-buster....
  10. May 16, 2017 at 11:01 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    cv joint?
  11. May 16, 2017 at 12:15 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Cv usually makes a clicking sound. Popping is typically ball joint, or lca bushings. Of course, that is typical not always
    wilcam47 likes this.
  12. May 16, 2017 at 4:11 PM
    grubburg
    2019 TRD OR MT
    it's only when the wheel is turned pretty sharp and i'm backing up.
  13. May 16, 2017 at 4:14 PM
    wilcam47
    Will
    Bourbon state
    yep
    thats why I was wondering about your CV joints.
  14. May 30, 2017 at 9:04 AM
    grubburg
    2019 TRD OR MT
    well it's more of a rubbing sound and it's only when the right front is turned inward. It's a discrete angle. If I turn it more, the sound stops. If it's not turned that sharp, the sound won't be heard.
    I checked the cv boots and they look fine. No evidence of rubbing anywhere.
    can't figure it out!
  15. Jun 1, 2017 at 4:08 PM
    grubburg
    2019 TRD OR MT
    HA! it was my front mud flap bent inward and hitting the tire!
    thank God it ain't no CV joint!
  16. Jun 5, 2017 at 10:08 PM
    wilcam47
    Will
    Bourbon state
    l
    least it was something simple...toyota mudflaps bend so easy...
