Weird sound-RPM dependent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chipnoreo, Dec 9, 2014.
  1. Dec 9, 2014 at 9:58 AM
    chipnoreo
    chipnoreo [OP] Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    So for about the last week my truck has been making this whirling/howling/kind of sounds like a siren on an ambulance sound. It only happens at certain times:
    1) It happens starting at 2500 rpm and is no longer noticeable (maybe just completely goes away?) at 3000.
    2) It happens in all 6 gears, in neutral, and with the clutch pushed in.
    3) The noise seems to only happen when the truck is warming up. Once it is at operating temp, it is no longer noticeable.
    Any ideas TW?
    It's a 2006 4x4 6 speed.....
  2. Dec 9, 2014 at 10:10 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    throw out bearing
  3. Dec 9, 2014 at 11:47 AM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Ive read up on the TO bearing quite a bit and this doesnt seem to match the complaints that most people have???
  4. Dec 9, 2014 at 12:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    idler pullies.
  5. Dec 9, 2014 at 1:21 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Possible, but I have had those going out before and its a different whine. Ill check those though.
  6. Dec 9, 2014 at 3:23 PM
    Pigpen
    Dan
    Northwest Montana
    Serpentine belt??
  7. Dec 10, 2014 at 10:03 AM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Mmm the belt is new in the last 10k miles....
    I appreciate the thoughts, but this is a pretty specific noise and just throwing out every common whine and whirl on the tacoma is not all that helpful to me. FYI, I have thoroughly looked into this on TW before posting and found nothing, hence my asking.
    I have replaced whiny idler pullys before (within the last 20k), my clutch has 110 k with no TO bearing issues (have looked into what to look for on those since it is such a common issue), and my serpentine belt is almost brand new.
    I am hoping someone has had this specific problem before. IT IS ENGINE TEMP DEPENDENT. It happens in and out of gear so I am guessing bearing of some sort.
    I guess to be more specific in my question, has anyone encountered this before and what did you do?
