Weird sqeaking noise. HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solution.45, Mar 6, 2014.
  1. Mar 6, 2014 at 8:09 PM
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    I have a squeaking noise that is coming from my truck only when I move. At idle it makes no squeak what so ever but as I progressively accelerate is gets louder. Its really annoying and I checked my serpentine belt (didn't take it off ) and it seems fine. It doesnt stop when I hit my brakes either so I assume its not that. It sounds like a belt though......... What could it be?????? Help me out fellas
  2. Mar 6, 2014 at 10:29 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    when was the last time you greased the u joints? start there
  3. Mar 7, 2014 at 1:53 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    +1. ^ Only when you move? Are you sure you dont have a U-JOINT going bad? Is it a constant squeak or does it sound rotational? The fact that it gets louder as you accelerate....Have a volunteer sit in the bed of the truck and see if they hear it from under the truck. Good luck.
