Weird start anomaly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BND17, Apr 20, 2025.
  1. Apr 20, 2025 at 10:05 AM
    BND17
    BND17 [OP] Member
    Ga, USA
    2017 SR 2.7 4cyl. Access cab
    As of yesterday I started having a weird issue on startup. The first instance was I used my remote start I installed several months ago (N2) and the truck started to turn over but then failed to start. I got in and turned it over again and it started. It took a couple turns longer than usual to start but it did start. I turned it back off and tried again and there was no issue starting this time. Later that evening I ran some errands and had no issues. This morning left for work and no start issues. This afternoon leaving from work I decided to avoid the remote start and start the truck the old fashioned way to see if it happened again. Well it started after cranking a little bit longer than usual but then pretty much immediately died. I started again and had no issues. The only real common denominator here is that both times it happened it was fairly hot out. I live in Georgia so it can be hot and humid. My first assumption is my battery is going out or my fuel pump is going out. I checked the battery voltage right after shutdown from a brief drive and it measured 12.91 volts. I changed the spark plugs about 2 months ago so I don’t think it’s those. anyone had issues like this or any clue as to what’s going on?
  2. Apr 20, 2025 at 10:52 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    THERE is your amswer
  3. Apr 20, 2025 at 12:45 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    How old is the battery?
    Get it load tested,,, or it's over 3 yo, replace it anyways if you want to avoid the downtime, it's nearly done anyways.
    BND17[OP] likes this.
  4. Apr 20, 2025 at 1:15 PM
    BND17
    BND17 [OP] Member
    Ga, USA
    Well you say that but it has nothing to do with it. It was the battery.
  5. Apr 20, 2025 at 1:16 PM
    BND17
    BND17 [OP] Member
    Ga, USA
    Decided to just stop by advanced auto and it pretty much immediately tested bad. Thanks for the help.
    Bishop84 and Chew[QUOTED] like this.
  6. Apr 20, 2025 at 1:32 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Most starting and electrical issues are due to a bad battery. Wish people would start there and just get a new battery instead of asking open ended and often way too lengthy questions on a forum.
