weird starter engagement after clutch and LUK flywheel replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by westport toyota, May 17, 2025.
  1. May 17, 2025 at 8:04 AM
    westport toyota
    westport toyota [OP] Well-Known Member
    Hey Im seeing if anyone has had a hard starter engagement issue after Luk flywheel and toyota clutch replacment? about 1 in 5 starts kinda hitting hard as starters kicks. Ive tried shimming starter at different angles and straight out with 1 washer on each bolt. Everything to do with the new clutch feels amazing its just the start. thanks for any help guys
  2. May 17, 2025 at 8:06 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Ide throw an oem non garbage starter at it, seen it sometimes on fords...
    Everything was fine & then you sneezed on it....
    Harsh grindy engagement after that...
    Dont cheap-out or you will be in no better place...
  3. May 22, 2025 at 8:22 AM
    westport toyota
    anyone? anyone?
  4. May 22, 2025 at 4:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like the problem was introduced with a change in clutch parts. If the ring gear is in the same spot then the starter should be fine
    I think you mean Luk brand flywheel right? Did you compare new and old on the bench before install?
    Sure you can try a new starter but don't be surprised if it doesn't help
    You either have a coincidental starter failure, a ring gear issue or the something isn't bolted up correctly
    Good luck
    Torspd likes this.
  5. May 22, 2025 at 4:36 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Fish a camera in the bellhousing and take a look. Did a clutch and flywheel on my 92 camry and less than 10'000kms later the ring gear was walking off and grinding on the back of the engine.... good thing I kept the factory flywheel. Got that machined, now just need the time to reinstall everything
  6. May 23, 2025 at 11:48 AM
    westport toyota
    every post and review said Luk is oem and tons of success . I read every post on tw including all throw out Bering posts as well . everything sounded good to go
    joba27n likes this.
  7. May 24, 2025 at 4:41 PM
    joba27n
    Nolan
    Alberta
    Luk is good. I find their clutches very smooth, tough as nails and durable. Only thing (kinda, not really) bad I can say about the clutches is I find they take a long time to fully break in.
    That said no manufacture is perfect and especially with asian vehicles, I feel like they don't fare well with anything but an OEM flywheel, and I was reminded of that with my flywheel experience mentioned above.
    Still, the actual problem should be pinpointed first. You can try putting some gear marker on the starter teeth then using it a few times to see where it's contacting. If it's near the edge then unfortunately you may have to take down the tranny again for further inspection.
  8. May 24, 2025 at 4:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Is there a shim between the flywheel and crankshaft? I'm having a tough time finding diagrams while eating dinner lol
  9. May 24, 2025 at 6:59 PM
    westport toyota
    no I shimmed the starter out with washers between tranny and starter. sounded the same but I will try that again . working on the starter is such a pain in the ass angles why on your back. I'm seeing the trough the wheel well method on k flo's channel
  10. May 25, 2025 at 7:27 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, early Tacos came off the assembly line with either LUK or Aisin clutch components. There is nothing in the VIN to identify which clutch your truck came.
    Unfortunately, the LUK clutch was plaugued with chronic problems on both the 5- and 6-speed Tacomas. There are several TSBs to address the matter and as IIRC instructions in the TSB to replace the problematic LUK clutches with the Aisin components.
    Unfortunately, the LUK problems persisted and Toy quietly dumped them as a supplier of these components in about 2012 or 2013. Not totally sure when production trucks started to appear with only Aisin clutches.
