Weird suspension sag. Help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Seanwarren13, Feb 4, 2021.
  1. Feb 4, 2021 at 12:52 PM
    Seanwarren13
    Seanwarren13 [OP] Member
    Sean
    2013 White 4x4 Tacoma
    Front bull bar with mounted light bar. Cube lights mounted at top corner of hood. 3” lift with 33” toyo a/t.
    I have a weird thing that I can’t figure out. My rear left suspension sags.. but only when I park it for more than an hour. As soon as I drive and hit a few bumps, it levels out and acts completely normal, but when I go into a store and come back out, it’s sagging again. I tested this by measuring before I park, and then after, where it drops multiple inches, then I purposely roll over a curb and it’s sits normal. it doesn’t sag when I’m driving or off-roading. Literally just when it sits still for more than an hour. I’ve never heard of this sort of thing and I want to see if any of you can help troubleshoot this before I spend too much money taking apart my suspension and buying stuff I don’t need to. I have bilstein 5100s in the rear and stock leafs.
  2. Feb 4, 2021 at 1:28 PM
    Joeyourbro
    Joeyourbro Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    The seals are probably leaking slow and the bumps pick them back up when you start driving, but don’t leak out fast enough to start sagging before you hit the next bump. I can’t imagine the leafs would cause this or what else.
    Seanwarren13[OP] likes this.
  3. Feb 4, 2021 at 2:10 PM
    Seanwarren13
    Sean
    That was my first thought joe. I need to look into it more. and I don’t have real measurements yet but I measured with my hand and it’s pretty obvious.
  4. Feb 4, 2021 at 2:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Shocks aren’t really what hold the rear of the truck up. They absorb “shock” for the most part.
    The majority of the weight is on the leaf spring.
    I suppose you could measure the shock length of each side after it sags?
    Then you’d know if it’s a shock/spring issue.
    If I were to guess, and this is total guess. (I have no idea)
    Maybe you have a shock that doesn’t fully “decompress” after the truck rebounds over a bump. Or maybe you have a weak leaf pack?
    Have you checked for a broken leaf?
