Weird symptoms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Apr 19, 2011.
  1. Apr 19, 2011 at 2:24 PM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    When shifting from park to reverse or drive, entire car jerks. When accelerating occasionally after a deceleration, get a jerking through rear end.
    Also, have an idle shake, this shake is constant at 2000 rpm's
    Acceleration feels rough and slow.
    46,500 miles on 2006 prerunner. V6 automatic
  2. Apr 19, 2011 at 4:05 PM
    USNavyTaco
    Goose Creek SC
    How do I check em?
  3. Apr 19, 2011 at 5:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    If you haven't done it already I'd change out the spark plugs. Check all vacuum lines for cuts or deterioration. Check that wiring around the egr valve is not caught or burnt. Try a little Lucas oil in with gas to free up any sticking injuectors. Make sure the piping to the MAF sensor is tight. There is a product (the name escapes me) that you add to the fuel tank that allows any water in the tank to be burned through the engine; that might help, too.
  4. Apr 19, 2011 at 5:31 PM
    USNavyTaco
    Goose Creek SC
    I too am thinking this could be a spark plug issue. I do not believe the originals (factory) were ever changed.
    I'm currently running techron concentrate through my gas on this tank.
    O and a question. When I shift from reverse to drive, is it normal for the car to move a bit? My fathers sedan does not move when shifting gears, my Tacoma has a noticeable jerk and sometimes(rarely a non metallic sounding clunk)
  5. Apr 19, 2011 at 5:35 PM
    2010nctaco
    2010nctaco Well-Known Member
    Blake
    Concord NC
    2010 trd sport 4x4
    Maybe transmission mount?
  6. Apr 19, 2011 at 5:43 PM
    2010nctaco
    Blake
    Concord NC
    2010 trd sport 4x4
    Or motor mount, I know its different but I had a civic that has a bad motor mount and when u would take off or change gears it would make a loud metal to metal sound and clank.
  7. Apr 19, 2011 at 5:58 PM
    USNavyTaco
    Goose Creek SC
    Thought about a tranny mount. But symptoms dont seem to fit, the jerk isn't a clunk, just the truck jerks a bit forward when shifting into drive, and tries to jerk back when shifting into reverse. Also there is no metallic clunk.
    There also is no significant jerk when it shifts while accelerating.
    Also, mileage, 45,000 and tranny mount is shot? Seems unlikely.
    Regardless, I'm getting new spark plugs and throttle body cleaned next oil change. (about a thousand miles) (mid to late may)
    May also take the approach of driving it till something breaks. I have a 3 year, 36,000 mike extended warranty anyhow.
  8. Apr 19, 2011 at 6:08 PM
    2010nctaco
    Blake
    Concord NC
    2010 trd sport 4x4
    Just a thought.
  9. Apr 19, 2011 at 6:18 PM
    USNavyTaco
    Goose Creek SC
    Thanks. Well I got an answer from my friend about the jerking.
    I just called my friend who works for a tranny shop. He said it's normal to feel a "jerk" because with an automatic. The load is now being placed on the engine to " drive" the car. Whether it be forwards "Drive" or backwards "Reverse". When you are at a stop and release the brakes, the car moves forward right? And when you are in reverse backing up, you release the brakes and move backwards right? Same principle applies here. The jerk is simply u, the brakes, and the frame fighting the engines torque making at attempt to move. This sounds logical to me. He said though if it makes a metallic thunk, or thinks while shifting and accelerating, that this is a sign of a bad tranny mount.
  10. Apr 19, 2011 at 6:23 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Personally, I'd check and adjust (tighten up) the rear brakes; they may not be holding the truck correctly when stopping or stopped. When you're driving and apply the brakes does it feel like the rear brakes are coming on first, or at all!? Properly adjusted rear brakes will make your front brakes last alot longer, too. That fuel concentrate along with barely firing spark plugs (let's be honest) would cause rough idling. Change those plugs asap.
  11. Apr 19, 2011 at 6:32 PM
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    sub'd
    I kinda have the same thing...i feel like it wasn't there when i bought the truck
  12. Apr 19, 2011 at 6:34 PM
    USNavyTaco
    Goose Creek SC
    I had my brakes checked when i got 2 new tires installed in the rear last week. They said all was well. Even took me into the service area of my mechanics shop to show me the status of em, yes, pads are getting worn, but no more than expected sitting in bumper to bumper traffic everyday. I've been using this shop for 2 years. Never had a problem and I trust em fully with my vehicles
  13. Apr 20, 2011 at 9:56 AM
    USNavyTaco
    Goose Creek SC
    Well. Heres the status. Acceleration is back. Weird eh? But idle is still a bit rough. As I said, plugs are going next oil change, I simply do not have time to take it before then.
  14. Apr 21, 2011 at 8:17 AM
    USNavyTaco
    Goose Creek SC
    Clank has gotten worse. Entire trucks jerks after a 1-2 second delay when shifting from drive into reverse and park to drive and reverse. Guess I just wasted 18 grand on a lemon. Now definitely starting to hate toyota.
    Maybe I should have bought a chevy silverado like I originally intended. this problem went from me being concerned to me being extremely angered.
  15. Apr 21, 2011 at 8:24 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    Reach under the truck when it's in park and twist the drive shaft back and forth, see if you have a lot of play. If you do, that would explain the clunk you are getting.
  16. Apr 21, 2011 at 8:26 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    What you are noticing is normal. Either way you need to change your spark plugs due to mileage but it will not fix the issue.
  17. Apr 21, 2011 at 8:41 AM
    USNavyTaco
    Goose Creek SC
    davtopgun - checked driveshaft,no play in U joints :)
    rjclemen - the clunk in the tranny is normal? Some times its not bad at all, some days feels like the damn truck is gonna fall apart.
  18. Apr 21, 2011 at 8:49 AM
    fjrmurph
    fjrmurph Well-Known Member
    Stand beside the truck and have someone cycle the transmission through park,drive,reverse. Lots of time you will hear sounds that will help identify the problem. If there is something wrong with the drive train that might help or it could be engine related.
  19. Apr 21, 2011 at 8:52 AM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    I honestly get the same thing. I feel like on cold days it does it more often. I think it is just one of those things that happens with our trucks. But really? I mean that is not a very big issue all things considered. I mean I had a BMW X5 (worst car on the planet, I swear) that was plagued with issues. But my truck? Nothing other than the vibes from the lift, which aren't bad and I am not bothered in the slightest by them.
