Weird Transmission and temp gauge issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by matts113, Nov 9, 2019.
  1. Nov 9, 2019 at 12:13 PM
    matts113
    matts113 [OP] Active Member
    2007 Regular Cab
    My 2001 Tacoma 4x4 with the 3.6L automatic has been really messed up lately (160,xxx). This morning I drove it out to go for a run and it drove fine on the way out. Revs little higher till engine warms up, which is typical. But, on my way back (20min later) the temperature gauge goes up just under the redline and my truck suddenly wont shift correctly either. Almost feels like transmission slip but it just wont shift correctly at all. I definitely think the temperature gauge issue is tied to the shifting issue as they happen simultaneously. My scangauge records a normal engine temperature though (195-198) while this all happens. I was just curious if anyone would know something about this?
  2. Nov 9, 2019 at 12:18 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    https://www.tacomaworld.com/threads/drivability-problems.538955/
    Thank goodness this stud dude came back and posted what fixed his problem. Sounds similar to yours. Check out the link. I had to search as I've never heard of this or ran into it. But makes sense as a possible culprit
    matts113[QUOTED][OP] likes this.
  3. Nov 9, 2019 at 12:20 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check your ground wire on the left front inner fender by the battery. The one that go's into the harness.
  4. Nov 9, 2019 at 12:26 PM
    matts113
    2007 Regular Cab
    ground looks fine
  5. Nov 9, 2019 at 12:29 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    also the one on the right front of the engine. These 2.
    cruiserguy likes this.
  6. Nov 9, 2019 at 12:52 PM
    matts113
    2007 Regular Cab
    Those grounds are solid as well.
  7. Nov 9, 2019 at 1:15 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Got me beyond that. Maybe there's something to the link @cruiserguy posted
  8. Nov 19, 2019 at 6:39 AM
    matts113
    2007 Regular Cab
    My issue has progressed. My truck will now shudder and die while in drive. Let mechanic look at it and it didn't act up for them so now its stranded in my driveway. The other day I turned it on to let it warm up, put it into reverse which it engaged, then I put it into drive and truck started to shake then die, with my A/T Temp light coming on. The next day I went to try and run it again, when I put truck in reverse it didn't engage as my truck didnt move when I released the brake, it did the same non-engaging thing in drive before as well. Any more Ideas, I am so lost right now.
  9. Nov 19, 2019 at 7:17 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Have you checked your transmission fluid? I'm sure you have, but you didn't mention it.
    There is a documented issue (more on 3rd gen 4runners than Tacomas) where the radiator will crack and the transmission fluid mixes with the coolant. They call this the "Strawberry Milkshake" because that's what it looks like. It's easy to check for, just look at your coolant.
  10. Nov 19, 2019 at 8:07 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Sounds like the lock up part of the converter is trying to engage killing the motor. Do you have the Factory service manual?
  11. Nov 19, 2019 at 8:12 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  12. Nov 19, 2019 at 8:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What is this?
    Factory temperature gauge is for our engine; did yours come equipped differently?
    When's the last time you serviced your transmission? This would include replacing the filter and not just the fluid.
  13. Nov 19, 2019 at 8:24 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I believe it's 2001 and older that has a a/t temp light. My 04 doesn't have one. It turns on at an ungodly 280 degrees though.
  14. Nov 19, 2019 at 9:01 AM
    matts113
    2007 Regular Cab
    Trans fluid looks good pink/brown, haven't checks for any strawberries milkshakes but I wouldn't think that's the problem. I had oil and filter replaced 20k ago and my mechanic never said anything about chucks or sketchy stuff in pan. I still think it's a tcc solenoid but the repair shop I took too said it ain't that... I'm 1.5 hour drive from my normal mechanic (at school).
  15. Nov 19, 2019 at 9:03 AM
    matts113
    2007 Regular Cab
    And even though the light comes on I don't think it's overheating as it comes on even without moving the truck.
  16. Nov 19, 2019 at 9:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Unrelated to your issue at hand, but 20k miles on the same filter and oil is a bit much :boink:
    If I were you, I'd drain the transmission fluid and drop the pan to see if you've got anything funky in there. You've got 3 magnets in there that'll grab any metal particles/pieces.
  17. Nov 19, 2019 at 9:52 AM
    matts113
    2007 Regular Cab
    Iya going back to mechanic Friday. I'll have him do typical tranny oil and filter stuff. Might have him put new solenoids in for the heck of it too.
  18. Nov 19, 2019 at 11:03 AM
    nzbrock
    Noah
    San Marcos, TX
    I thought the automatic transmission fluid change interval was more like 50-75k miles. This obviously has to be adjusted based on use though.
  19. Nov 19, 2019 at 11:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lack of reading comprehension; I assumed he meant engine oil since he just said oil and filter.
    Would make sense now if transmission fluid and transmission filter was serviced 20k miles ago.
  20. Nov 19, 2019 at 11:17 AM
    nzbrock
    Noah
    San Marcos, TX
    Yea you'd most likely have cooling issues with the engine at that point.
    You could just have something wrong with the sensor. It's located on the passenger side right where the 2 transmission fluid lines enter/exit.
    Are you getting any CEL Codes? DTC P0710 is for ATF temp sensor malfunction.
    Something else to check, sometimes the shift linkage can get knocked loose. So when you shift into reverse, you could be in neutral. Obviously you could check to see if it was of by shifting further.
    Does your truck have a "kickdown" cable? I know they went away sometime in 01-04. You can check this by looking at your throttle body, if you have 2 cables then you have it. This cable helps to set shift points based on throttle position. If it's not set correctly you will get strange shifting.
