Weird Transmission and temp gauge issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by matts113, Nov 9, 2019.
  1. Nov 19, 2019 at 2:17 PM
    matts113
    matts113 [OP] Active Member
    2007 Regular Cab
    Only code is P1135 code, I can check for the cables and linkage
  2. Nov 19, 2019 at 4:26 PM
    Glamisman
    Glamisman Well-Known Member
    I hope these are correct for your year... having said that, check powers and grounds first. In the E.C.T. diagram you will see that the throttle position potentiometer and the Trans over temp light are connected.
    matts113[OP] and gearcruncher like this.
  3. Nov 20, 2019 at 6:15 PM
    gearcruncher
    Canadain bumper technician
    Yes , first thing to check is the converter clutch lock up circuit . Its a good size circuit on these trucks as it combines the vehicle speed sensor , the transmission temp sensor , the throttle posistion sensor and the converter clutch lock up solenoid . I would be looking for a broken wire to the temp sensor first . The converter clutch will not lock up if the truck doesnt get a temp sensor reading from the computer . The computer also needs to see vehicle speed as well as how deep your foot is down on the gas pedal by means of the throttle position . The above posted files are an excellent source for diagnosisng your issue
  4. Nov 25, 2019 at 5:06 AM
    matts113
    2007 Regular Cab
    Update: Mechanic looked into my check engine code (P1135) for my upstream O2 sensor heater circuit. Found a bad ground, wire looked good but needed to be readjusted for proper ground. Seems to have fixed my problem, no drivability problems yesterday. Taking truck on a few 3-4 hour drives this weekend, that'll be a true test. All colorful dash lights are off!
    gearcruncher, cruiserguy and tony2018 like this.
  5. Nov 25, 2019 at 5:12 AM
    tony2018
    tony2018 Well-Known Member
    Good to hear, hopefully it works out fine and you can have turkey weekend off from investigating the truck issue.
    matts113[QUOTED][OP] likes this.
  6. Nov 25, 2019 at 8:24 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Were was the ground wire?. Glad you got it fixed.
  7. Dec 2, 2019 at 6:24 PM
    matts113
    2007 Regular Cab
    I believe it was the ground point on the passenger side back near the dash in the engine bay. I forgot what one the mechanic specified. I drove it for 8hours over holiday weekend and no more issues, so problems solved.
    mechanicjon and cruiserguy like this.
  8. Dec 2, 2019 at 6:27 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Dude that's so great to hear! I imagine even more for you of course but this whole thing was such a roller-coaster ride man! :D:cool:
  9. Dec 2, 2019 at 11:59 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    :D:D Ground wire.:hattip:
