Weird transmission problem…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Quicksilver32, Jul 27, 2021.
  1. Jul 27, 2021 at 8:08 AM
    Quicksilver32
    Quicksilver32 [OP] Member
    Sitting at dealer now…
    About a week ago when putting it in D, the truck would not move. Revved the motor, nothing. Tried it again, brought the revs to 3.5k and still wouldn’t budge. Turned it off, cycled the parking brake, shift lever and then restarted. Same thing. Finally, I revved it higher and it went BANG! and the truck shook and lurched forward. It drove fine but got mileage in the 10-12 range for a gallon on so. At dealer right now and they found no issues on test drive. But they found codes on the computer that require a Telematics ECU replacement. Not expecting that? I had the TRD lift kit installed a while back and am wondering what in the hell is going to happen to all those calibrations they had to hand enter for the camera and grill sensor. What a bitch!
  2. Jul 27, 2021 at 8:12 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Low on fluid?
    jetfishn and Skydvrr like this.
  3. Jul 27, 2021 at 8:17 AM
    Quicksilver32
    Apparently everything checked out fine with the driveline…
  4. Jul 27, 2021 at 8:20 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    My guess is that it was parked after either driving in heavy rain or washing. The rear shoes rusted to the drums. I try to get in the habit of not setting my parking brake after washing. This has happened to me, but not as severe.
  5. Jul 27, 2021 at 8:28 AM
    Quicksilver32
    It has been really rainy here. Could be the culprit?
  6. Jul 27, 2021 at 8:41 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Given that everything checks out fine with the gearbox, Threebeers might be onto something here.
  7. Jul 27, 2021 at 8:42 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I had mine sitting overnite after a car wash with ebrake set. When I put it in D (or R) the next day, truck wouldn’t budge, but I could tell that something was siezed up (turned out to be ebrake after being engaged, wet). Was your situation similar or was the trans actually slipping?
  8. Jul 27, 2021 at 8:44 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Sounds like a bad/broken torque converter.
    shakerhood and zoo truck like this.
  9. Jul 27, 2021 at 9:11 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Or if the parking brake was stuck and they were revving it to 3.5k until something went bang then that definitely didn’t feel good to the TC. lol
  10. Jul 27, 2021 at 9:13 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    his parking brake was probably seized and maybe he fucked up his torque converter by clutch dropping it at high RPM
    OvrlndBigAl[QUOTED] likes this.
  11. Jul 27, 2021 at 9:17 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Why is it that some folks fail to post the year, model & trim level of their Tacos when chasing solutions to problems?
    It's to every TW member's benefit - including the poster - to share these details. Others may have a similar problem (same year/model/trim) OR, better still, have experienced the same problem AND found a solution.
    My rant is over for today.
    LV-TAC and joeyv141 like this.
  12. Jul 27, 2021 at 9:18 AM
    cryptolyme
    Virginia
    because it's not relevant
  13. Jul 27, 2021 at 9:43 AM
    CT Yankee
    CT
    I beg to differ.
    Many times it is VERY relevant.
    shakerhood and buddypauly like this.
  14. Jul 27, 2021 at 9:50 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    How do I drop the clutch in AT?
  15. Jul 27, 2021 at 9:52 AM
    cryptolyme
    Virginia
    sorry. you don't. but it sounds like the transmission didn't engage until about 3500 rpm which would put some serious strain on the torque converter which could amount to the "bang" OP heard
  16. Jul 27, 2021 at 10:44 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    So the dealer found that the ECU is trashed?! That doesn't sound like a e-brake related problem.
    shakerhood likes this.
  17. Jul 27, 2021 at 10:45 AM
    Quicksilver32
    It’s a 2020 OR 4X4 AT, 39k miles…
  18. Jul 27, 2021 at 10:46 AM
    Quicksilver32
    Im not sure what it is… Telematic control module?
  19. Jul 27, 2021 at 10:50 AM
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    Same here.
  20. Jul 27, 2021 at 10:54 AM
    dagobert
    dagobert Well-Known Member
    Did the truck "squat" or feel like it wanted to move when you gave it gas or did it feel like a neutral drop when it finally went?
    SR-71A likes this.
