Weird TRS HID issue with one side not lighting
Discussion in 'Lighting' started by memario1214, Nov 7, 2016.
  1. Nov 7, 2016 at 12:17 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have a weird issue with my TRS projector setup that just decided to start about 3 weeks ago. It all started when my passenger side just would not fire, and then occasionally when I would drive it would fire up and work just fine until I turned them off again. I thought OK... I have had my current setup in there for about 3 years. Wouldn't surprise me if some of the components are starting to get tired. I ended up purchasing an entirely new HID kit (ulbs/ballasts/ignitors/relay harness). I install it and everything seems to be running hunky-dory for about 2 days.
    Fast forward to current day and I am still fighting with these things. Here are my observations:
    • The light will never come on the first time. Generally, when I cycle the lights on/off both sides will eventually fire up after a few tries. This morning I could not get the passenger side to fire.
    • If both lights do come on they remain on without issue.
    • The problem side is ALWAYS the passenger side. I have swapped all equipment more than once (ballasts, ignitors, etc), changed grounding points, the works. Only thing I have not tried to do is to take the trigger from the passenger side OEM plug, but the problem there is that the power lead wouldn't reach any longer.
    • The lights no longer turn off together. When cycling the headlights back to off, the passenger side will stay lit for fractionally longer. It is probably less than half of a second, but it is noticeable that they are not turning off at the same time.
    I have read some threads on HID planet with people stating similar conditions as my own, and also stating that it is a Toyota thing. My whole deal is that I have been running HIDs/Projectors for over 5 years and have never had an issue with this in my truck.
    I rarely am at a loss when it comes to electrical issues, but I am reaching out on this one... Frustrated. Tagging a few who I think may be able to help, but if anyone has suggestions please send them my way!
    @TRSAndrew @TRSJimmy @inwood customs
  2. Nov 9, 2016 at 2:25 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Colton,
    That is super strange. Especially having the kit work flawless for 3 years and you're having the issue with the old kit as well as new kit. Not sure if it's vehicle specific, but my tacoma's passenger side is a second or so delay when turning off and on. Of course, grounding points are the biggest thing. Is your grounding point metal to metal? If there's paint, I suggest scuffing it a bit. I know I had to move my grounding point twice, even after running it flawless for about a month, kinda weird. I don't think swapping the trigger from the driver's side to the passenger side will help it to be honest. Morimoto D2S kit correct?
    Jimmy
  3. Nov 9, 2016 at 3:43 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I had similar issue with passenger side not turning on, it was a bad ground. Fixed that, and it comes on every time now.
  4. Nov 10, 2016 at 6:26 AM
    blam827
    blam827 Well-Known Member
    Brent
    Peachtree City, Ga
    White 2019 TRD Sport 4x4
    TRD Shift knob TRD gun metal wheels w/ 265/65-17 BFG LED fog lights K&N Cold Air Intake Redline Hood Struts Morimoto XB Headlights MBRP Dual Cat Back Exhaust Toyota Mud Guards LED interior light kit ( blue ) Meso Stage 2 tail lights Meso Puddle lights Meso chrome delete interior Meso Gas Hole Meso Ultimate turn signals Front Anytime Camera Mod Supreme Suspension 3”/2” lift Roll up Tonneau Cover Southern Styje Off-road Slim-line front bumper Warn 10000lb winch with synthetic rope Matt Gecko LED Blue Bed lights / front white hood light De-badge and De-vinyl Tinted front windows. TRD Pro Skid Plate Bed rug Auxiliary fuse block bracket Blue Sea aux 6 circuit fuse block w/50amp circuit breaker JLT oil separator Remote starter mod KTJO bowl lights. ( blue ) Cali raised ditch lights w/brackets Winch shut off switch. Still to do: Rock sliders.
    I kinda ran into the same thing. Mine worked great. I love them. Every now and then the drivers side would not come on. Turn them off then back on and boom, it works, all is right. Last night i left work they worked fine . I stopped for dinner and got back in and drivers side wasnt on. turned them off then drivers side came on. Thinking something wasnt right, I saw a reflection and my passenger side wasnt on. Cycled them again and it swapped again. Did this several times and then both just stopped completely. Lucky for me I was in my neighborhood and my DRLs and fogs were enough to get me home. Came into work this morning they still didnt fire. I swapped in my stock bulbs and they work fine. I sent an email to the retrofit source and waiting a reply. I love the kit. Like i said, everything has been working great untill recently. I bought my kit in Feb 2016. I did smell something funny like a hot electrical kind of smell though. maybe the relays? I dont know. Once i hear from them Ill follow up.
  5. Nov 10, 2016 at 12:05 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @memario1214 Just to confirm... I know you said you bought a whole new wiring relay harness along with other components, but did you install the new harness? Or just end up using the existing one?
    The reason I ask is because I'm troubleshooting my own HID problem. (Retrofit from Rechelon/Burt. Ran fine for 3 years, now both low-beams won't turn on intermittently)...... and I think my problem is due to the MotoControl module do-hickey thing. I have a new wiring relay harness on the way from TRS to see if it is indeed the problem.
  6. Nov 14, 2016 at 2:37 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    Interesting. I would check the relays. You can also swap the relays from one side to another and see if the problem follows. We are doing our best to catch up on all of the emails!
  7. Dec 29, 2016 at 11:26 AM
    blam827
    Brent
    Peachtree City, Ga
    Finally got to checking out what happened to my lights. Since I live 30 min south of ATL i just went up to Retrofit Source. Carlos took care of me and bench tested all my stuff. Turns out both bulbs were bad. They looked fine, no blackness or blown look. I think that even surprised them a little. He replaced the bulb under warranty and all is right now. TRS is the shit!!
    TRSJimmy and solscooter like this.
  8. Jul 3, 2021 at 11:43 AM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    Did you ever figure this issue out?
  9. Jul 3, 2021 at 1:30 PM
    memario1214
    Colton
    Missoula, MT
    I didn’t. I got a new relay and it helped a bit, but when it was cold out they still had attitude occasionally. Don’t have the truck as of a few months ago so I don’t have a true solution.
    JoshS[QUOTED] likes this.
