Weird Truck Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Aug 26, 2009.
  1. Aug 26, 2009 at 12:42 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Im haveing a annoying issue going on with my truck! When i come to a stop at a stop sign or light then i try to take off it will die! Unless i barley push on the gas then let of then repete the process again and aftr 2-3 times of doing this it drives just fine. It relly sucks when i try to take off it dies right in middle of tracfic and could cause a wreck.
    THE CEL codes is po172 po172pd
    I cleaned the MAF and checked for VAC leaks
  2. Aug 26, 2009 at 12:48 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I had this happen to me with an old car, turned out it was the brakes locking up cause they needed to be replaced, this is probably not the case with yours just thought I would put in my 2 cents
  3. Aug 26, 2009 at 2:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Cleaned the MAF sensor (it may be bad) how about 02 sensor ? It sounds like a fuel delivery problem. Does it miss or stumble under acceleration? Fuel filter ever changed ?
  4. Aug 26, 2009 at 6:44 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Have you checked for leaks in the exhaust? Exhaust gas leakage can trigger that CEL.
  5. Aug 26, 2009 at 9:22 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Front bank 02 sensor is crapping out most likely. It happened to me not that long ago.
  6. Aug 27, 2009 at 12:11 PM
    1999tacotrd
    yeah MAF has been cleaned. No missing at all while driveing it drives fine just stumbles at take off! exhust leak would be loud correct? the o2 senors is it the top or bottom one? and would'nt that have its own cel light? I can clear my CEL light and it dosent do it near as bad as when its on so i think its eather the MAF or O2 thats bad
  7. Aug 27, 2009 at 7:59 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    :rolleyes:
  8. Aug 27, 2009 at 8:10 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    check the idle control valve and try also cleaning the throttle body, it souns like an MAF,or IAC problem to me
  9. Aug 27, 2009 at 8:21 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Throttle Position Sensor. Try removing it and spraying it with electrical parts cleaner. It's held on with 2 very small phillips head screws and a small wiring harness plugged into it.
  10. Aug 27, 2009 at 8:23 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Start at the source, your fuel lines.
  11. Aug 27, 2009 at 9:06 PM
    1999tacotrd
    I did have a CEL light for the TPS but i cleaned it and its not on now. Would the TPS cause this problem?
    And where is the IAC i can try cleaning that
  12. Aug 28, 2009 at 3:54 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    under the throttle body, it controls your idle
  13. Aug 28, 2009 at 4:37 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I had a similar issue with an 02 Tacoma. It would stutter and sometimes stall at stops, but was fine while moving. Cleaning the TPS resolved the problem. I don't know if there is a way to test the sensor, but perhaps it's faulty.
  14. Aug 28, 2009 at 9:31 AM
    1999tacotrd
    Well theres a local man here who has a rolled 1997 4runner he says it has the same engine as mine and he's parting it out so i will try and see if he will sale me the TPS then i will go from there and see if it fixs it if not then i will get the MAF and 02.
    I know autoparts will test these senors for u but more then likely they will claim there bad even if there not just so u have to buy a new one from them.
