Weird Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by TN2000Tacoma, Dec 10, 2010.
  1. Dec 10, 2010 at 1:48 PM
    TN2000Tacoma
    TN2000Tacoma [OP] Member
    Frank
    Maryville,TN
    00 Single-cab 4x4
    Aftermarket head and tail lights. Billet grill. BFG-All terrains,some nice wheels.
    I got a 2000 Tacoma single cab 4wd.
    I just changed my U-joints a few months ago because they were clicking.Along with the clicking came a bad vibration while driving.I figured changing the u joint would fix,it didnt make the vibration go awy. It only does it at 40-45 mph.I took it in to have the tires balanced and rotated.They told me my left inner tie rod was bad and needed changing pretty soon.Would that cause it? I just cant figure out why its vibratin so bad. Can anyone help me figure this thing out??
  2. Dec 10, 2010 at 8:02 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    anybody? anything at all would help right now
  3. Dec 10, 2010 at 8:16 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    you mark your driveshaft before you removed to make sure it was installed the same way in came out?
  4. Dec 10, 2010 at 8:18 PM
    desertdude59
    especially if its a 2 piece driveshaft it could be off balance.
  5. Dec 10, 2010 at 8:19 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    yes, Im pretty sure its put back in the same way it came out. Could autozone sold a bad u joint to me? only thing i can think of.
  6. Dec 10, 2010 at 8:23 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    is there anyway to tell the exact spot its supposed to be in?
  7. Dec 10, 2010 at 8:23 PM
    desertdude59
    Possible. Sounds like a balancing problem. Take it to a driveshaft shop and have them check it out for you.
  8. Dec 10, 2010 at 8:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Give more detail on the vibe. Where do you feel it? Steering wheel? Or seats?
  9. Dec 10, 2010 at 8:27 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    I can feel some of it through the steering wheel but also in the seats. Makes everthing in the truck rattle like crazy.
  10. Dec 10, 2010 at 8:28 PM
    desertdude59
    not unless you marked it
  11. Dec 10, 2010 at 8:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If it was steering wheel only, its likely an issue with the front wheels. Since you fell it in the seats, I'm inclined to think the issue is in the rear.
    If you put it in neutral or depress the clutch (coasting), does the vibe go away?
  12. Dec 10, 2010 at 8:59 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    yea as long as im givin it gas it will vibrate.
  13. Dec 10, 2010 at 9:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That narrows it down a bit, from transmission back I would say. Since you've replaced all of the U-joints, that leaves the tranny or the rear diff. Any play in the pinion bearing? You did replace the u-joint in front of the pinion right?
  14. Dec 10, 2010 at 9:06 PM
    TN2000Tacoma
    Frank
    Maryville,TN
    00 Single-cab 4x4
    naw, i dont think i changed that one, Is that the one closest to the rear end? if so i didnt change it.
  15. Dec 10, 2010 at 9:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Worth investigating. Better than the pinion bearing.
