weld-on muffler inlet/outlet
Discussion in '1st Gen. Tacomas (1995-2004)' started by SCSPerformance, Oct 27, 2011.
  1. Oct 27, 2011 at 4:07 PM
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    i didn't get any input in the general auto. section so maybe you gen1 guys can share your thoughts with me.
    i'm curious as to why guys are using mufflers with center inlet/offset outlet when the stock muffler is center/center. i would think it would make more sense to use a center/center when welding in a new muffler[​IMG]. am i missing something here? i know any exhaust shop can make any configuration work, but....
    input please[​IMG]. i've got something in the works for the tacoma guys. any feedback is appreciated, thanks.
  2. Oct 27, 2011 at 9:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Center in/Center out made more sense to me also. Otherwise the muffler doesn't sit flat. I wanted mine to be tucked up as high as possible so no chance I could catch it on anything when wheelin.
    Go with your gut.
  3. Oct 29, 2011 at 9:50 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    thanks for the input. i wonder if anyone else knows why they chose offset/center:laugh:.
  4. Oct 30, 2011 at 5:25 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I ordered a Gibson 55122s (cent/off) at first accidentally instead of the 55112s (cent/cent) - had a few beers before clicking "Order"... may have explained the confusion.
    So then i ordered the 55112s
    I showed up to the muffler shop with both, told them to pick the right one for the install job and i'll return the other. They installed center/offset 'vertically.' the lower corner of the can hangs down below the frame by about 2 inchs - not too happy. Should've just given them the center/center and been done with it.
    Still need to fix it, but I have other more important things on the list.
  5. Oct 30, 2011 at 10:53 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    im offset in/center out..Resampled_2011-09-10_19-28-17_496_00eb2b091d4c71adc1022cd52987224a4c8a5986.jpg
  6. Oct 30, 2011 at 11:32 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    i notice that a lot of times the mufflers are welded at an angle or like DblCabMN's truck vertically which will work fine, but it's not the best look imo. plus in some cases, you lose clearance in that area.
  7. Oct 30, 2011 at 2:37 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I had my shop weld on a Magnaflow 18" muffler. The guy chose an offset in/center out. It sits "vertical" also but doesn't hang down too low, I'd say its even w/ the frame. I don't know why they chose to install that particular muffler (they had numerous in stock) mayb it had something to do w/ the bends they had to do for me and where the stock piping was..IDK
  8. Oct 30, 2011 at 6:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    who cares how its looks lol i don't ever go under there to see how my exhaust looks lol
    and actually its angled up to keep it above the frame rail..so no..no clearance is lost..
  9. Oct 30, 2011 at 7:12 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    i care, lol:spy:. i appreciate the feedback Monte!
  10. Oct 30, 2011 at 8:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol of course you would Vin :rolleyes: haha
