Weld on or Clamp on muffler?
Discussion in 'Performance and Tuning' started by Lentsnh, Apr 8, 2010.
  1. Sep 1, 2017 at 3:00 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I had to get mine welded. 2.50 in and out. the diameter difference from 2.25 to 2.50 is quite a bit.
  2. Sep 1, 2017 at 3:09 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    is a 2.25" ID muffler too small to slip over the factory exhaust tube?
    yes I tried to measure but I'm still confused and don't want to buy shit that doesn't fit :luvya:
  3. Sep 5, 2017 at 7:14 AM
    coopcooper
    alberta canada
    2.25 wont slip over you would need to use a sleeve. 2.50 slips over but the gap is pretty large and a clamp might leak. I know 2nd gen piping is 2.25. not sure about 1st gen but I would imagine its the same.
  4. Sep 5, 2017 at 8:50 AM
    Wulf
    rock raisin
    ah gotcha. I got a good deal on a 2.25 ID muffler online so I guess I'll have to figure out what to do once it comes in. I got quotes for $70-300 to weld it in
  5. Sep 5, 2017 at 5:19 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Any muffler shop will be able to expand the muffler ends slightly to overlap the existing exhaust pipe. 70-300 seems excessive. I added a 2.25 resonator to a 2.25 pipe .. was charged 40 for the weld.
  6. Sep 5, 2017 at 5:56 PM
    Wulf
    rock raisin
    Right, $40-50 seems pretty reasonable. I would do the work but I won't have a welder for a few more months.
    One guy quoted me $600 plus because he said he would have to replace all of the exhaust piping (it's not rusted through) :rolleyes:
  7. Sep 10, 2017 at 2:32 PM
    Wulf
    rock raisin
    will a 2 1/4" OD tube fit inside of the factory tube and the muffler so I can clamp both?
  8. Sep 23, 2017 at 9:40 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Just had a shop put on a magnaflow. Its a 22" body so i knew it wouldn't be too loud but I thought it might be a little more noticeable. Already had cut tailpipe after axle and they welded existing pipe back on. Question is could i cut it after muffler say 8" to 1'? Its kinda angled upward so id need to get it pointed downward but any issues with this. Maybe crap getting in mufflerIMG_3538.jpg
  9. Sep 24, 2017 at 12:09 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    How hot does exhaust get?
    We do have plastic beds
    DubfromGA likes this.
  10. Jan 6, 2018 at 3:49 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I did a weld on muffler system last month using a Black widow venom 250 muffler. http://www.blackwidowexhaust.com/mu...nter-SKU-BW001-C/p/35648298/category=15730041 They are worth looking into.
    I previously had a flowmaster series 50 muffler 1in/2out running split exhaust that came out of the back of the truck. I loved that system and the sound but it rusted and I needed to make another exhaust. I got my exhaust built earlier this month using a Black widow 2.5" Venom 250 muffler and I already have a aFe Stage-2 Si Pro 5R Cold Air Intake System Dry filter installed. With the old exhaust I noticed that after 3k rpm you would loose the sound of the muffler because the intake sound would take over. After having the new exhaust for about a month now the biggest thing that I noticed is a pretty consistant power band and also engine sound. There is no drop of one sound for another. As the RPMs get higher the whole engine system sounds strong and happy.
    I really like the sound of the Venom 250 on my truck. The initial firing up sound is aggressive and loud enough but doesn't scare small children. It was 11F this morning while starting the truck in the video. With that said, your neighbors will definitely know when you have started your truck because the exhaust note travels inside the house easily. Just under normal idle while sitting at a light or in a drive through you wont notice it to much, but once you get on the throttle you and everyone around you will hear it. Getting onto the highway or passing anyone puts a smile on my face each and every time.
    The biggest thing that I noticed with this muffler compared to the last system that was on my truck is how much "quieter" the Black widow muffler sounds inside the cab compared to outside the truck, It doesn't sound annoying or overly loud. It has some hum at 1500 rpm, so going 35 down the road you might have a little hum but not annoying drone. At 2k RPM while doing 70mph the exhaust is comfortably quiet and easy to drive, but once you bring the motor up to 3200 RPM she stops sounding like a Tacoma and makes me smile. The company Black widow is worth looking into to for sure.
