Weld on sliders in the northeast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HuntnTruk, Jan 11, 2012.
  1. Jan 11, 2012 at 6:28 PM
    HuntnTruk
    HuntnTruk [OP] Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    For any of you guys in the northeast or anyone who is familiar with the salt belt, would you have any reservations putting weld on sliders on your truck? I am concerned that the grinding the paint of necessary for welding will inevitably start to rust without me knowing. I understand that you have to repaint it once you're done welding but it seems like it can still rust underneath the gusset plate. Am I worrying too much or is this a legitimate concern to have.
    Oh and by the way... the reason Im asking is because Im getting in on the BAMF group buy. As all of you should. We only need a few more orders to get the full discount.
    http://www.tacomaworld.com/forum/garage-workshop/180798-b-m-f-rock-sliders-all-trucks-12.html
  2. Jan 11, 2012 at 6:38 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    imo you are worrying too much. the welding is going to have little to no effect on the ability to withstand rust, provided you primer it properly and repaint after the welding is done. don't think twice about it.
  3. Jan 11, 2012 at 6:44 PM
    HuntnTruk
    Kevin
    Indigo SR5 4x4
    Yea I will end up doing it but I just wanted to hear if it was a bad idea or not.
    Nice to see another 'cuse taco
  4. Jan 11, 2012 at 6:46 PM
    kidrobot7
    kidrobot7 Well-Known Member
    Adam
    Vermont
    01 Tacoma sr5
    well I am quite experienced with salt and rust but if you repaint everything properly and put some Rust-Oleum over it if you want to be safe. When everything is said and done all your metal will rust away regardless up here. I've had my sliders on for just over a year and I haven't had any rust problems yet. sprayed the welds with 5 or 6 layers of black and a quick layer of rust-oleum when I installed them. Spot free ever since.
  5. Jan 11, 2012 at 10:30 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    IMHO, you have a valid concern, as rust will form between the flange and the frame rail, as any rustproofing will be burnt off between the two during the welding. It will eventually force the two apart, with enough force to bend both sides. Eventually is the key word though, but if long term happy tacoma ownership is your goal, I'd opt for bolt on sliders if you can find a suitable alternative.
  6. Jan 12, 2012 at 4:06 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Bolt on sliders
  7. Jan 12, 2012 at 6:38 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    mine are welded on as well and I sprayed them with rustoleum bed liner (several coats). No issues whatsoever
  8. Jan 12, 2012 at 8:57 AM
    HuntnTruk
    Kevin
    Indigo SR5 4x4
    Thats a good idea. I think I will spray mine with bedliner just on the gussets after welding in an attempt to seal it a little better.
