Welded blocks on brake drums - what are they?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poodle Head Mikey, Sep 28, 2014.
  1. Sep 28, 2014 at 1:16 PM
    Poodle Head Mikey
    Poodle Head Mikey [OP] Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    2007 Base w/2.7
    When I was replacing the rear brakes today I flipped the drum over so the open side kind of 'slapped' down onto the concrete. I always do that with drums to knock out any nasty black-soot brake dust. But this time a small steel block about 1/4" thick and maybe 5/8" by 1 1/4" long popped off the exterior side of the drum. The 'block' had a pressed dimple in the center - as does it's previous place on the drum. I imagine it was spot-welded in place originally. I checked the other side and found the mark for where it had apparently been - but that one has obviously been gone for some time.
    What are these brake-drum blocks?
    Why are they there in the first place?
    What harm can come from them being missing?
    "Balancing Weights" seems like the obvious answer - but the drums are cast and then machined symmetrical, they are very close to their rotating centers, and both weights appear to have been the exact same size. And how likely it is that both drums needed the exact same sized weight to balance them. <g>
    So? Anybody really Know what they are?
  2. Sep 28, 2014 at 1:22 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Balance weights
  3. Sep 28, 2014 at 1:25 PM
    Taco'09
    Taco'09 Well-Known Member
    This^^^for sure. Some aftermarket like the Centric Premium have them too and Centric confirmed they are balance weights.
  4. Sep 28, 2014 at 1:26 PM
    File IFR
    Central MA
    The OP does not and will not believe it.
  5. Sep 28, 2014 at 1:30 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    They are there to cause turbulence in the wheel to help spread chemtrails making them more effective.
    Or, they are indeed balance weights.
    You pick.
  6. Sep 28, 2014 at 2:18 PM
    Steve E
    Steve E Well-Known Member
    Southern Missouri
    2014 TRD Sport DCSB 4x4, 2021 Highlander Limited AWD
    I'm kind of leaning towards the chemtrails.
    Steve........
  7. Sep 28, 2014 at 2:37 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I always thought the accepted and recommended way of cleaning brake dust was to use brake cleaner spray??
  8. Sep 29, 2014 at 9:23 AM
    Poodle Head Mikey
    My thought being that there's only so much duct that can collect. So even if I made it all spotless - in a month it's back to the same level of dust. So just knock it off / out of the drum and call it good enough.
    PHM
  9. Sep 29, 2014 at 9:24 AM
    Poodle Head Mikey
    So? How did you reach this conclusion? <g>
    PHM
  10. Sep 29, 2014 at 9:26 AM
    Poodle Head Mikey
    So I guess now I need new drums, eh?
    PHM
  11. Sep 29, 2014 at 2:36 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Don't worry about them, I lost mine around 60K and kept the drums till 125K. I actually glued the first one back on with JB weld, the second I didn't bother. Crappy, over-priced drums! They're $110 each, even after market, so make them last!
  12. Sep 30, 2014 at 9:41 AM
    Poodle Head Mikey
    I'm going to run from Philadelphia to Tampa in about twelve hours soon - so if the brake drum balance is a factor I will soon know it. <g>
    If I get new brake drums I guess an answer would be to paint them and prevent the weights from corroding off the drums. That seems to be what happened with mine.
    PHM
  13. Sep 30, 2014 at 10:02 AM
    81SHOVELHEAD
    81SHOVELHEAD Member
    Galveston Texas
    2014 access cab 1-4
    Could be balance weights, but being a machinist with machining of cast iron parts experience, I am
    leaning more to it being there to eliminate the harmonics /brake chatter in the thin cast iron drums .
    Have you ever seen them re-machine the drums? They wrap a rubber bungee cord around the drum to stop the harmonics during the machining process.
    Just my guess though
  14. Oct 1, 2014 at 6:25 AM
    Poodle Head Mikey
    My first street bike was a 1937 Indian Chief. Or; what was left of it by then. <g>
    Thinking of it from a machining perspective: where could any imbalance large enough to require that large heavy steel balancing weight come from? It's a concentric casting, concentrically turned, and then five evenly spaced holes are drilled in to the face. What weirdness would they be balancing against?
    And from looking up brake drums for sale it seems that every one has the same sized single weight attached to it. How likely is it that the imbalance that is being corrected is always exactly the same? <g>
    PHM
  15. Oct 1, 2014 at 6:52 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I don't know if they are balancing weights and/or for harmonics.
    Being in the investment casting industry for 29 years has taught me a few things about castings...they have variability.
    Concentric machining of the ID bore to the OD cast surface will not remove the casting variability.
    Castings in the machining industry are known as "snowflakes"...
    Good question though OP...I've seen these for years. My vote is balancing weights.
  16. Oct 1, 2014 at 8:43 AM
    81SHOVELHEAD
    81SHOVELHEAD Member
    Galveston Texas
    2014 access cab 1-4
    Yes it was a 1981 FXB (First duel belt drive & 80" (1340cc motor) it now has been lowered & 16" wheels makes it look like a FAT BOY.
    Not fast but fun to ride
  17. Oct 1, 2014 at 11:49 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    spread out two equal dollops of JBweld
    jbweld the weight back on
    put a blob of equal jbweld opposite the weight
