welder isn't heating up enough
Discussion in 'Sports, Hobbies & Interests' started by rab89, Sep 27, 2010.
  1. Sep 27, 2010 at 5:53 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    So I just picked up a lincoln 180S, it's an old stick welder.
    it came with a larger than normal 220V 3 prong plug in.
    I want to plug it into my dryer plug, as it's the only 220V plug I have.
    So I bought a dryer plug, connected my wires, leaving the neutral wire hanging loose as there are only 3 prongs to be used.
    Now when I try to weld, it's like it's not heating up or something, at 30 amps it makes a small spark when I touch it to the metal, but not much, and even at 180 it makes a stronger spark, but wont do anything near welding.
    Any ideas why this is not working?
  2. Sep 27, 2010 at 6:38 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hello :) thanks for reading
  3. Sep 27, 2010 at 6:50 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    do you have a volt meter by chance?
    if you do, check Open Circuit Voltage from the electrode to the ground lead. there should be about 60-80 volts. if its lower, then your diodes are bad
  4. Sep 27, 2010 at 6:52 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    great, so just touch my meter to the ground and put the other end inside the electrode holder?
  5. Sep 27, 2010 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Never mind....Read the post wrong...
  6. Sep 27, 2010 at 7:01 PM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    That should get you there- ground lead to electrode
  7. Sep 27, 2010 at 7:07 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ok I set my meter to the 200 volts reading, and I got 7.7 which would be 77 volts right?
    I hope so because I burned up the wires for my meter right after I checked that haha
  8. Sep 27, 2010 at 7:19 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    77 volts should be good.
    is it an AC or DC welder?
  9. Sep 27, 2010 at 7:19 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  10. Sep 27, 2010 at 7:26 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    in that case, we dont have to worry about the diodes. 77 volts is still necesary though.
    Hmm... the only things in the ciruit is the trasformer and the amperage selector. its pretty simple
  11. Sep 27, 2010 at 7:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    umm, Im no electrician but I think that does mean 7.7 volts when the meter reads that. Im totally guessing though.
  12. Sep 27, 2010 at 7:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hope your wrong :)
  13. Sep 27, 2010 at 7:39 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    The leads should not have burned up.
  14. Sep 27, 2010 at 7:42 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well I was messing around with the meter, put the positive in the 10A socket instead of the normal one, and then they burned up, i should have realized that my welder is over 10 amps haha.
  15. Sep 27, 2010 at 7:45 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I tried that and i'm getting nothing, when i pull, it just drags along making sparks, but not enough to do anything. my neighbor is a welder and he said the same thing, basically it's not getting enough heat..
  16. Sep 27, 2010 at 7:45 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    which 10 amp socket? where the output stud enters?
  17. Sep 27, 2010 at 7:47 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thanks anyways, I'm sure my neighbour would have gotten it if that was the problem
  18. Sep 27, 2010 at 7:50 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    on the left side there is a 10A socket. thats all I did.
  19. Sep 27, 2010 at 7:53 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I would use the positive lead on the right socket to test AC voltage
    7 volts on a digital meter normaly means 7 volts
  20. Sep 27, 2010 at 8:09 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    but it's dependant on which setting your on is it not?
    I really wish I knew how to use this meter, I should probably learn
