welder isn't heating up enough
Discussion in 'Sports, Hobbies & Interests' started by rab89, Sep 27, 2010.
  1. Sep 27, 2010 at 8:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    not usually, thats why I was confused.
  2. Sep 27, 2010 at 8:15 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    test it on your 110 power outlet. if you get 110v there, then you know you what your range is
  3. Sep 27, 2010 at 8:18 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well, I'm hooped now, I wrecked my leads haha
  4. Sep 27, 2010 at 8:21 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    damn, i guess ill be subbed till then
  5. Sep 27, 2010 at 9:14 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    AHH! I found some old leads!
  6. Sep 27, 2010 at 9:22 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    let's go over this, I set my meter to the 200 volt rating, and then connect positive lead to the elctrode holder ( in place of a welding rod) and the negative lead on my ground clamp. and it should read around 80 volts?
  7. Sep 27, 2010 at 9:28 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    correct. if you get half, then your only getting 120v to the trasformer. if your getting 80v but not enough heat while welding, then theres a loose conection that is not letting the amperage through. And make sure the welder is set at its highest setting
    Make sure your not in the amps setting by accident
  8. Sep 27, 2010 at 9:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    k so I did that, when I had my amperage on my welder set to 70amperes, i read 38.9volts on my meter, when I turned the welder up to 180, I was only reading around 30volts and when I had the welder down to 30amperes, i was also reaing around 30 volts
    On the front of my welder it says max welding capacity 180 amps at 25 arc volts, does that mean anything to anyone?
  9. Sep 27, 2010 at 9:34 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    sounds like im getting 120v then doesn't it?
    why would that be? I'm using the dryer plug in...
  10. Sep 27, 2010 at 9:37 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  11. Sep 27, 2010 at 9:38 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    it could be the wiring in the input plug that is off. if you have the ground wire and the hot lead in a cicuit, then you will only get half of the 220 volts.
  12. Sep 27, 2010 at 9:41 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ok I'm new, can you explain further?
    edit: do you mean when I wired my welder to the dryer plug I have something backwards?
  13. Sep 27, 2010 at 9:50 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    yes, double check that
    im trying to find a diagram to help you see the circuit.
  14. Sep 27, 2010 at 9:54 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ok, so this is all from welder to dryer plug...
    the dirty white wire goes to white
    black to black
    green to red
    and the neutral wire on the dryer plug is just hanging not attached to anything..
  15. Sep 27, 2010 at 9:58 PM
    #35
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    lets clear this up.
    do you have plug
    A.
    or
    plug
    B.
  16. Sep 27, 2010 at 10:07 PM
    #36
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    lol I had this...
    I opened it up, and wired it to this...
  17. Sep 27, 2010 at 10:11 PM
    #37
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    okay, the try green to the top round stud. black and white to the two side ones. leave the red wire off and none on the bottom one.
    hope theres no big difference in canadian input plug wiring.
    the plug you installed in normally for three phase power
  18. Sep 27, 2010 at 10:14 PM
    #38
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    it's cord to cord though, not just cord to plug, so I don't know which color is which..
  19. Sep 27, 2010 at 10:23 PM
    #39
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    You need to let someone that knows what they are doing do this
  20. Sep 27, 2010 at 10:24 PM
    #40
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    why? Yuma seems to know what he's doing, and he's helping me learn, what's wrong with that?
