welder isn't heating up enough
Discussion in 'Sports, Hobbies & Interests' started by rab89, Sep 27, 2010.
  1. Sep 27, 2010 at 10:26 PM
    #41
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    you could check continuity from the plug leads to the power cord cables. then you will see which is which
  2. Sep 27, 2010 at 10:34 PM
    #42
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    you mean to find out which 2 are power and which is ground?
    I'll do it tomorrow when there is some light.
  3. Sep 27, 2010 at 10:42 PM
    #43
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I highly doubt that green goes to red. i believe that you just need the black and white for it to work. and the green is there for protection. i would remove the red wire from the curcuit and test OCV again.
    Im sure you have the 220v. we just need to find which two wires are carrying it.
  4. Sep 27, 2010 at 10:43 PM
    #44
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    k, I'll go try that right now then. sure would be sweet to get this going!
  5. Sep 27, 2010 at 10:45 PM
    #45
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    The D shaped terminal is the ground. The hot wires are on each side of that and the neutral the one you are not going to use is the one at the top, it's the "L" shaped terminal. Green never goes to red. That is the ground wire connected to the 120 volt hot wire. Not a good idea.
    You should have four colors. A green "ground" and red "hot " a black "hot ' And a white neutral that is not going to get used.
    You need the ground connected for safety. It is what blows the breaker when there is a problem. That is why it's not working you have it wired like a idiot so it's only has 120 volts and the case of the welder is live.
  6. Sep 27, 2010 at 10:50 PM
    #46
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    regular 220v plugs only have 3 studs.
    why do the canadian ones have the 4th one?
  7. Sep 27, 2010 at 11:03 PM
    #47
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Prob should have done this from the start.
    on the left of the photo is the dryer cord that I will have plugged into the socket.
    on the right goes to the welder. what goes where?
  8. Sep 27, 2010 at 11:06 PM
    #48
    Trap
    Indego Ink TRD OR
    Cause here it's a 120 / 240 volt plug. The timer on the dryer does not run here at 240 volts it only runs at 120 volt. Hence the extra wire.
    The motor of the dryer is probably not 240 volt also. Just 120 volt.
  9. Sep 27, 2010 at 11:07 PM
    #49
    Trap
    Indego Ink TRD OR
    Ok Red wire from the dryer side to the white wire on the welder side.
    Black to black. Green to the bare copper wire. Marrette it good and tape it up well. It should actually be in a box. You even have to marrette up the white dryer cable that is not being used. Depending on what's happening in the house it could become live sometimes.
  10. Sep 27, 2010 at 11:10 PM
    #50
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    k i'll go give that a shot.
  11. Sep 27, 2010 at 11:54 PM
    #51
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    that time between posts was me doing my first project :D
    I call it "ART"
    hahaha, thanks so much guys, this is gona be FUN! my first actual project, after lots of practice, will be a bed bar that mounts with the cap on.
  12. Sep 28, 2010 at 7:45 AM
    #52
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    Ditto! But I am an electrician.
  13. Sep 28, 2010 at 7:43 PM
    #53
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Great to hear that you got that thing running :thumbsup:
