Welder Repair Help!
Discussion in 'Garage / Workshop' started by tbturner47, Jun 6, 2010.
  1. Jun 6, 2010 at 10:56 PM
    tbturner47
    tbturner47 [OP] Well-Known Member
    '16 Barcelona Red TRD Off Road
    So I was at my grandpa's house the other day and I saw this old Century 120 Volt wire feed welder buried in his garage. The plug was cut off the end of the power cord and he said he hasn't used it in a while. He told me I could have it if I fixed it. (Hell yeh)
    So I got a plug that would work with it and wired it on. It turned on fine, but as soon as the fan kicked on it sounded like it was drawing power or something. Like it had the normal operating noise but then it would suddenly droop down for a second then back up again. Also, the lights in my garage would dim every time it drooped. I've used all sorts of power equipment on this outlet before so it SHOULDN'T be the outlet.
    Does anyone have any ideas? I'm pretty handy with fixing things and working with electrical equipment but I know practically nothing about welders so any information would be helpful.
  2. Jun 6, 2010 at 11:00 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    To me is sounds like its pulling a lot of amps for the breaker max to the breaker. or the Lights are on the same breaker that the welder is on. (which is the case most likely) My compressor would do that before I gave it its own outlet and breaker. My welder is also on its own breaker and outlet.
  3. Jun 6, 2010 at 11:06 PM
    tbturner47
    ok I'll look into that tomorrow. Also, I just tried the gun and the wire feeding spools didn't spin:(
  4. Jun 6, 2010 at 11:08 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yea my 110v welder would dime the lights then blow the breaker, so i had to put it on its own breaker.
  5. Jun 6, 2010 at 11:24 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    The Spool motor may be out.
    Yumatrd on here works for the company that Lincoln and Miller send all of their warranty items to. He would be able help you with this. He is the one that works on the welders. He's a super nice guy. :)
  6. Jun 6, 2010 at 11:48 PM
    tbturner47
    :Dawesome. thanks for your help
  7. Jun 9, 2010 at 8:18 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure it's the correct voltage. Some run on 220v. There maybe a short somewhere in the welding circuit. Have it serviced before you burn it up, or get the service manual for it. Then you can test it yourself.
    Regards,
    Dave
  8. Jun 9, 2010 at 8:18 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Missed the 120v tag on your post, sorry.
  9. Jun 9, 2010 at 8:32 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Does the welder have a plate stating the amps that it draws?
    If you have 12 gauge wiring and a 20 amp circuit breaker with no load from anything else you should be rated for up to 16 amps continuous power draw from the welder. If you have the newer 14 gauge wiring (smaller) and a 15 amp breaker you should be good for up to 12 amps continuous power draw. You can go up to the amp rating of the circuit breaker for a second or two on a standard slow-trip breaker.
  10. Jun 24, 2010 at 10:15 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    This could be a loose connection on the trigger circuit, a relay that is bad, or the main contactor is out. Send me the model number and specs and i should be able to pull out the wiring diagram.
