Welding for CMC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JsDCTRD, Feb 28, 2019.
  1. Feb 28, 2019 at 6:49 PM
    JsDCTRD
    JsDCTRD [OP] Well-Known Member
    Josh
    Houston, Tx
    2012 DCSB TRD
    Pelfreybroke steel front bumper BHLM T4R Trail Wheels Element LED 20” light bar Bilstein 6112/5160 Icon AAL
    I don’t weld, but work for a construction company and have plenty of guys that can weld for me.
    Question is would stick welding be too hot/too much penetration on the cmc?
    I know most people have it done MIG or TIG but I only really have access to rig trucks, and my guys don’t typically carry Argon...we just don’t use it much.
  2. Feb 28, 2019 at 6:53 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Just turning down the amperage and using the correct rod for the job will get you all set just fine. Your welder buddies will know, I wouldn’t worry too much.
    whatstcp and JsDCTRD[OP] like this.
  3. Feb 28, 2019 at 6:56 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    @shaeff
    It’s amazing what some good breakfast tacos will get you :D
    But thank you, sir.
    I did iron when I was in the field so I never learned all the fancy fun stuff.
  4. Feb 28, 2019 at 7:04 PM
    shaeff
    Hudson Valley, NY
    Right on! My guess is that they’d use a 6010/6011 rod (depending on their machines). The weld puddle sets up quickly as you move and they penetrate well. Also burn through rust and junk easily.
  5. Feb 28, 2019 at 7:25 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    That would be my guess too 6010. Good all purpose rod for multi position welding. It will not look pretty like TIG but the key is getting good penetration and even heat between the two metals. You can always hit the weld with a flap wheel to smooth the weld when done. Just make absolute sure you disconnect the battery!!!
    rileySB and shaeff[QUOTED] like this.
  6. Mar 1, 2019 at 7:25 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Most pro welders have access to MIG or TIG machines, even if they just have an old wire-feeder in their garage. Since the work is pretty visible here, I'd ask around your crew and see if someone has the right tool and can make it look purdy. On a side note, a cheap wire-feeder for your garage is money well spent.
    JsDCTRD[OP] and whatstcp like this.
  7. Mar 1, 2019 at 3:29 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    @whatstcp
    Assuming you've done this mod, where I can get them? Just in case.
  8. Mar 1, 2019 at 3:39 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    Awesome, thank you sir! I'll order them this evening as a CYA:spending:
  9. Mar 1, 2019 at 3:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was gonna say, be careful with the amount of heat they put into it so they don't cook the bushing. Small 1" welds jumping around keeps it cool, and it'll clean up nicely with a flap disc on an angle grinder when all is done.
  10. Mar 1, 2019 at 3:48 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    @EatSleepTacos
    That is the plan. Small stitch welds jumping from side to side and giving proper cooling time.
    EatSleepTacos likes this.
  11. Mar 1, 2019 at 3:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could stay on the same side if you wanted. Here's what I do whenever I do a CMC (I've done about 10)
    • Cut drivers side
    • weld drivers side
    • cut passenger side
    • weld passenger side
    • grind drivers side
    • grind passenger side
    • paint
    Bouncing back and forth like that between welding, grinding and painting works very well.
