Welding Nuts into Access Cab Rain Gutter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewprime1, Oct 6, 2016.
  1. Oct 6, 2016 at 11:14 AM
    andrewprime1
    andrewprime1 [OP] Well-Known Member
    Andrew
    Salt Lake City, UT
    2007 Tacoma ExtraCab SR5 V6 6 Speed
    So, I am curious about the possibility of welding nuts into the rain gutter channel of my access cab. Have seen post like this one discussing putting yakima landing pads into the factory threaded holes in DC trucks. The access cab does not have these factory mount points, so what are y'all fine peoples thoughts on just welding in some nuts?
    I figure that they're hidden by the gutter rubber strip anyway, so they don't need to be pretty. Not sure how strong they would be either, so that's a concern as well... I know very little about welding, but I know our roofs are made of steel, as a magnet sticks to mine. I have a friend who would do this for me for free and I hate the towers that grip into the door frame and f up the paint job.
  2. Oct 6, 2016 at 11:28 AM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Welding can eff up a paint job too. And harder to undo. Tread lightly here.
  3. Oct 6, 2016 at 11:32 AM
    andrewprime1
    Andrew
    Salt Lake City, UT
    True, its a pretty tight little channel, do you think a skilled welder would be able to contain the heat in such a way that it didn't affect the paint outside the rain gutter
  4. Oct 6, 2016 at 11:37 AM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
  5. Oct 6, 2016 at 11:40 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    I wouldn't weld anything to the roof personally but if it's a rack you're looking into, what about the Prinsu rack? I believe that attaches with rivnuts on acces cabs.
  6. Oct 6, 2016 at 11:46 AM
    andrewprime1
    Andrew
    Salt Lake City, UT
    Hmm, that's a really good idea, I have never seen anything quite like that. Its like a t-nut for metal! So I am assuming there is some amount of space between the bottom of the channel and the interior roof? I don't wanna seen bolts when I look up from the drivers seat, haha.
  7. Oct 6, 2016 at 11:46 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Nutsert FTW here. Would never consider welding in the channel myself
    Crom likes this.
  8. Oct 6, 2016 at 11:56 AM
    andrewprime1
    Andrew
    Salt Lake City, UT
    I am actually looking to bolt a landing pad down. I have a large canoe and the two bars on my shell are too far back to support the bow, as a result it rubs on the roof of my cab. I just want a bar that I can quickly take on and off.
    These guys -
  9. Oct 6, 2016 at 12:55 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yup nutsert or rivnuts. Only way I'd do it.
  10. Oct 6, 2016 at 1:04 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Give Rack Attack a call. I know they are not local but they may have a solution. I know on the double cab they have a Rhino Racks track that is basically riveted into the drip rail. Then you can add whatever towers/legs you want.
  11. Oct 7, 2016 at 4:34 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
  12. Oct 12, 2016 at 10:29 AM
    andrewprime1
    Andrew
    Salt Lake City, UT
    Thanks Squirt! I am going the rivnut/nutsert route for sure. Could you tell me how much room you had in there? Or how long your nutserts were? I am thinking that I want the longest possible nutsert to accommodate the longest bolt possible. Or do you think there is an ideal length?
    Also, still no moisture problems I assume?
  13. Oct 12, 2016 at 1:26 PM
    little squirt
    808 ALLDAY!!
    There isn't too much room in there. nutsert only grabs as thick as the roof sheet metal is. Don't forget, I think there is head airbag in there too. I also put too much pressure when drilling and went through my headliner one side little bit. Just take your time and maybe put tape on the drill bit so it will only go down so far. I also used marine grade white caulk to seal the nutserts, no issues yet after a year or so.
  14. Oct 12, 2016 at 1:32 PM
    vinnyp
    vinnyp Well-Known Member
    Summit County, Colorado
    2015 Silver Sky TRD Sport
    3" Lift, 18" Fuel Lethal Wheels, 33" BFG KO2s
    Rhino Rack makes a ditch mount system that works perfectly. They make a track system for the double cab, but there is a ditch mount bracket that does exactly what you are wanting to do then you can use the Yakima Landing Pad 6, The Thule 3114 Fit kit, or the Rhino Rack RLT600 quick release tower. The thread pitch is the same on all of these options. Clean look and super stout. It's what I do for a living. This is a better option than welding or just putting rivnuts into the ditch. You also want to be careful, because the Airbag canister is under the ditch as well...... Don't want to hit that thing.
    andrewprime1[OP] likes this.
  15. Oct 12, 2016 at 3:30 PM
    andrewprime1
    Andrew
    Salt Lake City, UT
    Wow, thank you. I like that idea quite a bit more. Is this what you're talking about?[​IMG]
    I already use Rhino racks and I really like them! I like that this is meant for the application I have in mind.
    erikjon likes this.
  16. Oct 12, 2016 at 3:56 PM
    vinnyp
    That is it... just make sure to get the correct width bracket as they make two sizes. If you have any questions, call Rhino Rack. They have great customer service and will be happy to help. You will be happy with it.
  17. Oct 12, 2016 at 9:29 PM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    i have the Rhino Ditch mount set up. I like the adjustability and selection of accessories. Most of all, I like how easy it is to remove. Simply unlock and lift the covers up on the towers then you can lift the cross bars and what ever is attached to them off the truck for storage.
  18. Oct 14, 2016 at 7:28 AM
    tgear.shead
    tgear.shead Well-Known Member
    I have a better option for you....
    Don't weld, screw, or otherwise attach anything to the roof. Welding or screwing anything in, WILL result in rust. That's a guarantee. The last thing you need on any vehicle, is providing any kind of access for the elements to begin causing rust.
    Instead, find a truck rack, like this; http://www.tdotperformance.ca/smitt...gle_shopping&gclid=CI7FpdK_2s8CFQUehgodNzcOng
    ** of course, you'll need one that is the right size for a Tacoma.
    These things will just hook on to your bed rails (or bed floor for the super heavy duty kind), and extend over the cab. Even the bed rail type will be *considerably* stronger than anything you can stick to your roof, and will NOT damage your roof in any way.
  19. Oct 14, 2016 at 7:52 AM
    tgear.shead
