Welding on rock sliders
Discussion in '1st Gen. Tacomas (1995-2004)' started by Saltwater-and-Hradrock, Oct 15, 2016.
  1. Oct 16, 2016 at 1:12 PM
    eon_blue
    Azusa, CA
    I can't remember, are you in on the MJT trip on the 30th of this month? Few of us from the wheeler's anon. thread are planning a trip on that Saturday. You should have a chance to use your sliders then :D
  2. Oct 16, 2016 at 4:29 PM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    What types of steel and heat treatments have you read/heard of in regards to truck frames? I'm really curious--this honestly hadn't occurred to me before. I did some searching and didn't find a whole lot. From what I could find, it looks like some frames are medium-carbon steel that has been annealed after assembly, which wouldn't pose much of a problem for careful welding. I wouldn't be surprised if some frames are more highly alloyed or have some sort of heat treatment that doesn't involve normalizing the steel though.
  3. Oct 16, 2016 at 4:40 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah I might be. That's a Sunday right ? My only day off lol
  4. Oct 16, 2016 at 6:09 PM
    Saltwater-and-Hradrock [OP] Member
    Ethan
    Denver
    99 Tacoma xtra cab 4x4 5-speed manual.
    Thanks everyone for the info! sounds like welding is the way to to go! The sliders where from my 93 4Runner. I thought they would fit my 99 Tacoma, however they did not. I could have modified them but I sold them with the 4Runner today.
    What is an affordable and functional brad for sliders?
  5. Oct 16, 2016 at 6:15 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Honestly, Trail Gear is real hard to beat on price. I have a set about to go on my 03 double cab and they are rock solid. I know several people on here have beat on them real hard and been more than satisfied with them.
  6. Oct 16, 2016 at 8:03 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I'm not sure what steel is used originally...
    and that question would be better posed with Dana Corp.
    ( ^ if they're even still the vendor/supplier after their prior fiascal )
    Of course...
    Whomever the supplier is... isn't likely to share their knowledge.
    It's likely not true spring steel...
    But it does have more memory then std. mild carbon steel
    as it generally returns to it's original form after being flexed severely.
    Mild carbon steel would just bend and not have memory.
    But I know it was not annealed to the point of becoming too rigid or brittle.
    'cause if it was... it would likely just shear/break when flexed.
    So because of the memory in the steel...
    I'd have to think it has special properties
    or was annealed a specific way.
    And weld heat can damage it's memory if one is not careful.
    It does weld fine... as good as any other mild carbon steel.
    But welding heat can remove the spring memory
    and cause failure if it isn't done properly/carefully.
    So basically one needs weld to the frame...
    without doing more harm to the steel's molecular make up.
    I don't work in the steel industry
    and so know little about it's material science
    or how it's made.
  7. Oct 16, 2016 at 11:45 PM
    eon_blue
    Azusa, CA
    yea that is a Sunday actually, probably better for me too...I'm sure we'll be talking about it more in the W.A. thread in the next week or so, I'll be sure you're tagged
  8. Oct 17, 2016 at 1:42 PM
    anthony250f
    Anthony
    San Diego, CA
    What time were you guys gonna hit the trail
  9. Oct 17, 2016 at 2:45 PM
    eon_blue
    Azusa, CA
    Not sure yet, we just threw the date out there and a few of us agreed on it. We'll start a thread or post for it later this week or early next week, most likely we'll start early (like around 8 or 9am). MJT isn't that long of a trail mileage-wise, but the difficulty can be unpredictable especially with the rain we just had. Last couple of times I did it, we hit the trail at 9 and were on the freeway home around 3
  10. Oct 17, 2016 at 3:16 PM
    anthony250f
    Anthony
    San Diego, CA
    Ok cool. I'm really far from the trail lol
  11. Oct 17, 2016 at 10:52 PM
    gbollom
    gbollom Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    Are you guys using DOM tube or plain ol ERW for sliders?
  12. Oct 17, 2016 at 10:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mine are made out of HREW, gotta remember what you're attaching them to though. Seems like for a little truck like this DOM isn't required but there's no downside either.
  13. Oct 17, 2016 at 11:03 PM
    gbollom
    Weatherford Tx
    I don't see a problem with attaching DOM to a scab plate and then to the frame. It's still mild still DOM, not chromoly
  14. Oct 17, 2016 at 11:06 PM
    Speedytech7
    No problems at all, my comment was meant more as a comment on strength of the Tacoma frame not so much the metallurgical compatibility of the two.
  15. Oct 17, 2016 at 11:09 PM
    #35
    gbollom
    Weatherford Tx
    Gotcha! Sliders will be important for me to build once I find a truck so I've been peaking around at Tacoma sliders
  16. Oct 17, 2016 at 11:48 PM
    #36
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    HREW has always been fine for me
    think I have one slight flat spot after 12 years of trail abuse.
    maybe DOM if ya tend to hammer on 'dem.
  17. Oct 18, 2016 at 12:05 AM
    #37
    gbollom
    Weatherford Tx
    Mine will likely never see extreme trail use. Mostly dirt and some rock/caliche driving around the deer lease. HREW would likely be fine as you said
