Welding
Discussion in 'Technical Chat' started by tacoma44x44, Jul 14, 2010.
  1. Jul 14, 2010 at 10:46 AM
    tacoma44x44
    tacoma44x44 [OP] Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    Hey i have done a little welding in my day and was gonna fab up some sliders and such for my truck. But i was wondering some people i have talked to they say you have to take extra care when your welding on a vehicle because you can potentially fry your electrical systems? Just wondering if there's any truth to this and anything else i need to know about welding on vehicles?:cool:
  2. Jul 14, 2010 at 10:47 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    unhook your battery
  3. Jul 14, 2010 at 10:48 AM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    Should i just pop the ground off or both?
  4. Jul 14, 2010 at 10:49 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    just the ground should be good
  5. Jul 14, 2010 at 11:00 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I do remove both so there is no possibility of closed loop, also make sure your welder ground is always as close to your welding point as possible.
  6. Jul 14, 2010 at 6:27 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
  7. Jul 14, 2010 at 7:33 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Its unlikely but if you are like the paranoid ones just take the ground off your battery
