Welding
Discussion in 'Off-Topic Discussion' started by Wixo, May 30, 2019.
  1. May 30, 2019 at 4:11 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Im looking at getting into welding as a personal hobby. I wanna do things like rocket stoves, little bbq pits, maybe fix a thing here and there. Im not looking into any of the more complicated fab type work. I was wondering if theres a welding kit Jr y'all would recommend for a beginner hobbyist. Like I said I just wanna weld some light stuff. Also a metal cutter. I would need to cut some pipes and what not to then weld together etc etc
  2. May 30, 2019 at 6:39 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    The Hobart 140 is a good rig to learn on and it’s 110V. A decent chop saw will safely cut just about any metal project you may come up with (while learning and later on).
    Wixo[OP] likes this.
  3. May 31, 2019 at 9:48 AM
    Wixo
    Hank
    Tint, LED interior
    What kind of a welder is it? Ive been looking around and for what I want to do Stick welding is what seems the most up my alley.
  4. May 31, 2019 at 9:49 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Any of the smaller Hobart welders. They’re mig and you can run them with or without gas.
    Wixo[OP] and whatstcp like this.
  5. May 31, 2019 at 9:55 AM
    Muddinfun
    Muddinfun Well-Known Member
    Stick welding is so 1960s. MIG welding is where it's at. Basically point and shoot. The hardest part is figuring out the settings on the welder. Play around with the settings on various thicknesses of scrap steel and you'll figure it out.
    Stick welding is for welding on rusty skyscrapers with a 30 MPH wind.
    MolonLabeTaco and Wixo[OP] like this.
  6. May 31, 2019 at 9:56 AM
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    2016 White Tacoma TRD OR AT 4x2 DCSB
    Faux pro grille, hood bracket mounted ditch pods, gator trifold tonneau cover
    Can I also suggest, some local community colleges do have welding classes and usually they will let you work on projects, things of your own design, etc. They'll have a lot of the equipment, and you can ask them what sort of starter set up you can put together once you finish up the class. Best part, classes won't break the budget.
  7. May 31, 2019 at 9:56 AM
    Jumbafri
    Jumbafri Well-Known Member
    The Lincoln Powermig 210 MP is a great starter kit. Its a dual voltage machine so it will run off of 110 or 220 with just the swap of a cable that plugs into the unit. It is a multi process machine so you can run it on MIG or Stick, and if you want to you can even run scratch start TIG on it. It has enough juice to do some good material thickness without needing to preheat. If you don't want to run shielding gas you can always run a fluxcore MIG wire.
  8. May 31, 2019 at 10:07 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    When I took a course to learn welding, way back in the last century, the instructor would not let us use a wire welder until we learned to use the stick. Said it was too easy and it was better to learn the basics first. Bought a basic stick welder, then a simple acetylene welder and finally a 120 volt wire welder. With the wire welder I had to rewire the circuit to use 10 gauge wire and a 30 amp breaker. Kept tripping a 20 amp breaker.
  9. May 31, 2019 at 10:08 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    We have a huge welding thread you might want to check out.
  10. May 31, 2019 at 10:13 AM
    azreb
    azreb Geezer
    TN
    Probably a good idea. I don't follow the thread because it is a catch-all. I am more interested in a discussion of specific problems when they occur.
  11. May 31, 2019 at 10:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have the titanium 140 welder from harbor freight. Runs $400. I really like it and have used it a lot on my truck. I too wanted to learn how to weld, so I watched A LOT of youtube videos and bought a shitty flux core welder off Amazon for $90. Got decent with that and upgraded to the one I have now. I've done 15-20 CMCs, cam tab gussets, rear shock relocate, etc. It's already paid for itself doing work for others, as well as if I were to pay someone else to do this fab work on my truck. It's an excellent skill to have.
  12. May 31, 2019 at 10:25 AM
    Wixo
    Hank
    Tint, LED interior
    You sir, that have used Amazon welders, what do you think about this one? https://www.amazon.com/ZENSTYLE-Por...ords=stick+welder&qid=1559322772&s=hi&sr=1-12
  13. May 31, 2019 at 10:28 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    MolonLabeTaco and whatstcp like this.
  14. May 31, 2019 at 10:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  15. May 31, 2019 at 10:30 AM
    Wixo
    Hank
    Tint, LED interior
    Thats kinda why I want to buy that one. I wanna enter cheap into the game and then Ill realize "yeah stick aint good" and then Ill get my self a nice 3 way kinda thing. Like I said before, Im not interested in some nice as welds as much as Im interested in just welding some metals every now and then.
  16. May 31, 2019 at 10:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Again, I still wouldn't do that. My prediction is you'd get discouraged and decide welding isn't for you because stick isn't easy. I'm a pretty decent mig welder and I'm sure I'd be terrible at stick. I've never tried because I don't need to do it. Check out the eastwood 135 as that's a pretty good welder for the money. Shop around as you may be able to find it cheaper.
    https://www.eastwood.com/mig-welder-110vac-135a-output.html
  17. May 31, 2019 at 10:39 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    you wont be able to weld thinner material with stick so I'd go mig. Hobart is made by Miller but at a cheaper cost and they are great welders. What is your budget?
    Wixo[QUOTED][OP] likes this.
  18. May 31, 2019 at 10:42 AM
    Wixo
    Hank
    Tint, LED interior
    One problem with MIG that Ive seen in my short tim googling the different types of welding, is that you have to buy a spool of wire which can be pricey, and you need tanks of gas etc. I dont want to have to use the gases etc, and since I will only be doing small project every now and then I would like the ability to buy only a few iodes at a time. I also dont want to get thrown off buy all of the settings etc. I mean if theres a "farm" wire I can run on a mig thats good for pretty much "everything" and theres a mig welder thats user friendly on the settings then I would go for it.
  19. May 31, 2019 at 10:43 AM
    Wixo
    Hank
    Tint, LED interior
    Dont necessarily have a budget, but since its going to be a hobby type thing, not an investment, I would like to not spend THAT much
  20. May 31, 2019 at 10:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What you want is flux core wire. Think of it like stick welding, coming out of a mig machine. It's still point and shoot, but there's no tank of gas to deal with. This is nice as well because windy situations don't matter. With gas shielded, the wind blows away that gas causing porosity.
    Pretty much any mig machine can run flux core wire. Then later on if you want to expand and try gas, the capability is there as well.
    It's really not expensive. When I was just welding a little bit, I'd buy a 2lb spool for about $20 on Amazon and that'd last me a great while. Buy it in .030 diameter for the most versatile metal thicknesses.
    Gunshot-6A and Wixo[QUOTED][OP] like this.
