Well damn im dumb
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justin723, Dec 21, 2009.
  1. Dec 21, 2009 at 3:25 PM
    Justin723
    Justin723 [OP] Dont judge me
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- 7 inch lift, ARB compressor, high pinion 4.88 with ARB locker, 4.88 open diff in the rear, PIAA 520 series lights up front, and 36 inch fire stick. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, Cobra LTD CB, and Weather Tech floor mats.
    Anyone know how much or where i can get a 5vzfe. im pretty sure i need a new one.
  2. Dec 21, 2009 at 3:26 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    haha what did you do?
  3. Dec 21, 2009 at 3:30 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    IDK sucked some water up in the engine so i cleaned the air filter and throttle body and now the engines making an extremly weird noice
  4. Dec 21, 2009 at 3:31 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    hmm, couldn't tell you what happened, but get some new plugs, change the oil and go from there i'd say
  5. Dec 21, 2009 at 3:35 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Did all that, im pretty sure my dumbass destroyed my truck, thing that gets me though i didnt hear anything till today and this happened yesterday.
  6. Dec 21, 2009 at 3:42 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
  7. Dec 21, 2009 at 3:42 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    get a vid of the noise if you can
  8. Dec 21, 2009 at 3:48 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    I hit the hole and the engine kinda died out as if you were to flood out a carburator. cranked it for a bit and she started right up. Ill try give me a second
  9. Dec 21, 2009 at 4:02 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Ok how do i upload videos?
  10. Dec 21, 2009 at 4:22 PM
    blackonwhite
    blackonwhite Well-Known Member
    06 white tacoma black 17' ssr wheels
    Wow first time ive ever seen another member from missouri
  11. Dec 21, 2009 at 4:24 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Yeah, where you from?
  12. Dec 21, 2009 at 4:27 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    if you sucked water into the engine it would hydrolock and that'd be that. Because it still starts and runs, i'm sure you didnt help matters, but it will be okay. new plugs, and maybe have a mechanic take a peek (unless youre good under the hood), and you'd be set.
  13. Dec 21, 2009 at 4:28 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    I changed the oil and it was a bit milky, is it possible i could of messed up my oil pump and thats why i only here it at higher RPMS?
  14. Dec 21, 2009 at 4:30 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Im pretty sure i did suck water in there because the air filter was soaked and the throttle body was muddy on the inside. i didnt submerge the whole front end just hit the hole fast enough to splash water under the hood and i think it just drowned the engine out.
  15. Dec 21, 2009 at 4:32 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Coulda messed up a bunch of things.. but you're still running.. so.. couldn't have been all that bad. Id suggest getting it to a mechanic to do a once over.. He'll charge you an hourly rate (80-90 bucks is a good deal) and just have the dood O.K. the truck. It'll be worth the peace of mind.
  16. Dec 21, 2009 at 4:38 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Well iam a mechanic and i cant figure it out, i even had my friend look at it hes a WMU grad with alot of experience and he cant even figure it out. It runs fine but around 2600 RPMS and higher it makes a weird ticking noise, to be honest it almost sounds like when you suck a little bit of water through a shop vac or something. Its only on the driver side where my valves are ticking as well.
  17. Dec 21, 2009 at 4:40 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    If thats the truth, and youre runnin a bit rough even after an oil change, you probably need to just change your plugs and you'd be set. All the water that was in the engine has since been burnt off..
    Start with plugs and check your wires (i'm dead sure those are okay)
    EDIT - have you done the plugs yet then?
  18. Dec 21, 2009 at 4:43 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Yes sir, put some E3 diamond fire in there.
  19. Dec 21, 2009 at 4:43 PM
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    Quick, put a forsale sign in that thing, park it out front and get away from it as fast as possible. Your best bet is to dump the truck since you have trashed it.
    Good Luck to the buyer LOL
  20. Dec 21, 2009 at 4:44 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Pulled the valve covers yet?
