Well i drowned it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veet-88, May 21, 2015.
  1. May 21, 2015 at 9:21 PM
    Veet-88
    Veet-88 [OP] Well-Known Member
    18 Tacoma DCLB sport
    Had a rather unfortunite incident over the long weekend and ended up sinking my tacoma. Yes water made its way into my intake. Plugs were pulled trail side to clear any water that could of collected in the cylinders dried everything out as well as i could. Once limped home manifold was all removed cleaned plugs changed air filter and oil changed. With all this done i have noticed it ticks a fair bit more than usual. Before hand i recall a slight tick just above typical injector clack. Ill be getting a video tomorrow. Narrowed down to the right rear corner of the engine (side that really sunk) wonder if anyone has made the same mistake or a few things that could cause this.
  2. May 21, 2015 at 9:28 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Ouch...I've read some stories here where some have sunk it, and re-vived it...good luck, OP.
  3. May 21, 2015 at 10:32 PM
    Veet-88
    More i look into it just sounds like normal valvetrain noise. Bit like a diesel have found multiple videos like it. Could of been there before and now that im looking for issues it just stands out like a sore thumb. Still revs free seems to run fine overall just seems loud now.
    https://m.youtube.com/watch?v=F2jYJfxjj8c
    Very similiar to this. Kind of feels a tad under powered than i remember as well.
  4. May 22, 2015 at 1:19 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like your near drowning is messing with your head. Sounds like the normal noisy 4.0 engine to me.
    R0dzilla75 likes this.
  5. May 22, 2015 at 10:01 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Crap can ruin your rings if to much water got injested with dirt in it. If it runs ok and doesn't blow white smoke out the tail pipe, you probably ok. No electrical problems?
    Sunk mine and got the bottom of the passenger seat wet and f'ed some sensors. Lights all over in dash now. Still runs great.
  6. May 22, 2015 at 10:33 AM
    Veet-88
  7. May 22, 2015 at 10:36 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Bummer!Good luck in the recovery!
  8. May 22, 2015 at 11:05 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Did your cat possibly blow out? My taco tick was real loud until i replaced that (also did head gaskets, but still).... Be sure and change your oil a couple times too... get some fresh blood in that thing
  9. May 22, 2015 at 11:44 AM
    Veet-88
    Oil was just changed plan on doing it again at 1500km, ill have to look into the cat. Id expect a low input o2 code for that though
  10. May 22, 2015 at 1:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    change oil MULTIPLE times within the next 100 miles.... you wanna get any contaminants out. Took a good 4-5 oil changes on a jet ski that got sunk for 5 minutes to get all the water out of the crank case.
  11. May 22, 2015 at 1:47 PM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Sounds perfectly normal to me. Like every other 4.0 I hear...They all tick but they sure do last a long time..
  12. May 22, 2015 at 1:58 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    +1 on this, although I wouldn't be quite that extreme. Maybe Seafoam it.
  13. May 22, 2015 at 2:35 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Sounds like a Cummins diesel.
    Agree with post 11 & 13. Seafoam the intake and crankcase oil. Change oil and filter then drive it.
    Probably last 300 k miles.
  14. May 22, 2015 at 3:50 PM
    nd4spdbh
    SoCal
    if it injested a good amount of water and sat in water its going to take MULTIPLE oil changes to get the water out. Good luck op. Spend 100 bucks on cheap oil and do back to back oil n filter changes after a full heat cycle... and keep changing it untill the oil doesnt come out milky.
  15. May 22, 2015 at 4:15 PM
    Veet-88
    Oil never came out milky the first time round. The entire engine bay was not under water just the intake corner was maybe submerged for 5 minutes tops. I dont think it took it ALOT of water but a good bit made its way into the intake, enough for the filter to be soaked.
    So far tomorrows game plan will be another oil change sea foam everything and check for any vac lines that could be plugged yet. Its ran for the week after my initial clean out and i have 0 condensation inside the fill cap where as when i worked at toyota pretty much everyone was filled with water build up.
    Pretty torn as to whats what with it right now most of the sound is right from what i have seen its just that diesel sound while reving is what has me stumped.
  16. May 22, 2015 at 4:48 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Engine under water will not hurt any thing unless it was running and drew water into a cylinder [water will not compress] if this happens the damage will be instant and catastrophic. [bent / Brocken rod or piston caused by hydrostatic lock. A small amount of water will not harm the engine. You state you pulled the plugs and cleared the cylinders so change the oil and filter and drive it any remaining moisture will boil away with engine heat. Not a big deal.
  17. May 22, 2015 at 4:51 PM
    Old School
    Old School You are ignoring covfefe by this member.
    A little off topic, but have you checked your other fluids for contamination?
  18. May 22, 2015 at 5:22 PM
    Veet-88
    Trans yes diffs no
  19. May 23, 2015 at 11:45 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Compression test it - a bent rod woud be quickly confirmed or eliminated. Pretty had to judge to sound from a video clip.
  20. May 23, 2015 at 4:06 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yes, this definitely isn't a normal 4.0 tick. Sounds like an exhaust leak to me but that's not it, it's something internal.
