Well i ended up getting the tacoma today for only $4800 it has some issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Apr 20, 2009.
  1. Apr 20, 2009 at 8:05 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi i bought my first tacoma today for only $4800 its a 1999 Sr5 TRD 4x4 with new mudding tires. It has 194k miles on it and runs good only physical problems i have seen is 1. the brakes will stick u push them in and they dont come all way back out causeing it to drive whit them in and will burn them up quick. Any idea on how to fix this? and 2. there are no turn singles! I check the fuse and the bulbs and there all fine only thing i can think of is a relay. Are these hard to replace? and here are the trouble codes the ODB-2 gave me i dont know what they mean mabye u guys know.
    PO172
    PO172pd
    PO770pd
  2. Apr 21, 2009 at 3:31 AM
    savoy
    savoy tacoma 4 life
    Josh
    Fort mcmurray, Alberta
    06 Tacoma double cab black
    Pro comp 6" lift, afe intake, flowmaster duel exhaust, dick cepek 35" mt's, and black XD rims
    had it on the highway yet ?
    if its any thing like my 99 it will sway like mad at speeds over 70mph
  3. Apr 21, 2009 at 3:48 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    did you try googling the error codes? if not take it to an auto parts store and they tell you what they mean and a relay is easy like a big fuse u just need to find it
  4. Apr 21, 2009 at 7:28 AM
    Bing0
    Bing0 Member
    02 4WD Limited Icons
    Icons, Cepek Rims, Bilstein Rears, Deck plate mod, Complete Sound Deadener with foam, GPS Kenwood
    Worn out caliper boots can be the issue with your brakes. The boots around the caliper piston act like springs and pull the caliper piston back out after braking. This may not be the cause of your braking problem but it is a good place to start.
    Bing0
  5. Apr 21, 2009 at 7:32 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    on the brakes I would guess a Master cylinder rebuild may be in order.
  6. Apr 21, 2009 at 10:13 AM
    1999tacotrd
    Yeah i had it on the highway didnt feel swaying at all but we didnt get it over 70 max. I will get some pics of it today and put it on here :)
  7. Apr 21, 2009 at 10:16 AM
    1999tacotrd
    Some on had rigged up a relay under the hood has wirse going to and from it i think it was for the turn singles one time. I will take a pic of it and put it on here
  8. Apr 21, 2009 at 10:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    P0172- Clean your MAF with MAF cleaner
    • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the sensors leak the silicone potting material used to protect the circuitry. There could be a leak
    • There could be a fuel or delivery problem
    P0770- Shift Solenoid E Malfunction
    Try flushing your tranny and changing the filter
  9. Apr 21, 2009 at 1:50 PM
    1999tacotrd
    where would the filter for the tranny be? is it on the bottom half of the transmission
  10. Apr 21, 2009 at 2:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Remove the transmission pan and the filter will be right there. You could also be low on fluid.
  11. Apr 21, 2009 at 5:39 PM
    1999tacotrd
    Ok i will do that. and its not low on fluid. when i checked it it looked overfull to me could that also cause the problem if there's to much fluid?
  12. Apr 21, 2009 at 6:01 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    to much is just as bad as to little.
  13. Apr 21, 2009 at 6:07 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    mine does it too:mad:
    Im thinking of adding some new sway bars and links, see if that stiffens 'er up
  14. Apr 21, 2009 at 10:17 PM
    1999tacotrd
    Heres the pics of the truck i had taken off the timming belt cover to inspect a rubbing sound but believe me i don't drive around with that off. Also i noticed that the truck sets up higher in front then in the back is that normal? if not what would cause that bad shocks or leaf springs?
    and in the 4th pic is the rigged up relay i have yet to figer out what it goes to
  15. Apr 21, 2009 at 10:21 PM
    1999tacotrd
  16. Apr 21, 2009 at 10:57 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    is the front suspension stock??? any spacers in place?? or a possible spring lift??
  17. Apr 22, 2009 at 1:13 AM
    1999tacotrd
    I have no idea if its stock or not i would assume its stock. I will get some pics of it tomorrow and post here
  18. Apr 22, 2009 at 10:59 AM
    Bing0
    Bing0 Member
    Too Little O's after the T's in this statement today.
    Peace,
    Bing0
  19. Apr 22, 2009 at 11:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    One less "i" in this one.
    Peace
  20. Apr 23, 2009 at 8:40 AM
    Ry1984
    lol
