Well lets hope 3rd time is the charm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcanders, Feb 7, 2011.
  1. Feb 7, 2011 at 1:01 PM
    bcanders
    bcanders [OP] Active Member
    I have a 6 speed 2011 and I continue to have brake fluid on my floor. The first time the stealership replaced the slave, 2nd time they replaced the master, now three weeks later same problem again. I called the attourney general to see what my rights were and he stated that in order for them to classify it as a Lemon they need to have attempted four times to fix the problem. This sucks... You spend 30,000 + for a new rig and it is already been in the shop twice with only 1500 miles on it. What a pain in my ass!
  2. Feb 7, 2011 at 1:04 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    It could be the clutch actuator as well. I don't know if it uses brake fluid, but I know that sometimes the fluid from the actuator can enter the cabin along the actuator rod.
  3. Feb 7, 2011 at 1:07 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    3rd time is also the lemon law in some states. I'd look into it. No reason to have a new truck in the shop more than once for same issue.
  4. Feb 7, 2011 at 1:20 PM
    Patrobs
    Patrobs Well-Known Member
    Patrick
    New Hampshire
    2012 Dbl Cab Short bed TRD Offroad
    I had the same problem happen to me but it was the clutch. Replaced the brakes twice then realized it was the clutch cylinder leaking. Make sure they check it all!
  5. Feb 7, 2011 at 1:32 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    is this jacking up your carpet? i would be pissed..
    my $ is on the clutch slave...sucks..please keep us posted.
  6. Feb 7, 2011 at 1:46 PM
    bcanders
    Washington state it is 4 times
  7. Feb 7, 2011 at 1:47 PM
    bcanders
    Nope first thing I ever bought was husky liners, thank god for them
  8. Feb 7, 2011 at 1:49 PM
    bcanders
    Yep that is where it is coming from. The plunger/ rod that is on the back side of the clutch. When I push in the clutch and release it, over and over soon fluid comes out
  9. Feb 7, 2011 at 1:50 PM
    bcanders
    I don't how much newer I can go than a 2011? So much for reliability
  10. Feb 7, 2011 at 1:52 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    one with 0 miles.:D
  11. Feb 7, 2011 at 1:54 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    seeing what dealer does.
  12. Feb 7, 2011 at 2:04 PM
    bcanders
    I will let you guys know what happens. :mad:
