Well my day has pretty much blowed!
Discussion in '1st Gen. Tacomas (1995-2004)' started by travis9287, Aug 27, 2010.
  1. Aug 27, 2010 at 1:00 PM
    travis9287
    travis9287 [OP] Roll Tide!
    Travis
    Sylacauga, Alabama
    Big ol POS
    Allpro APEX, 255's t4r wheels, Custom Rear Bumper.
    Ok well it all started a couple of weeks ago when i noticed a oil leak in my garage. well i checked it out and i was almost sure that it was oil pan gasket. well college hit me pretty hard and i was completly broke. i didnt have the money to fix it so i just kept oil in it until today. i went to the parts store and bought a oil pan gasket. a oil filter, belts,and 6 quarts of Royal Purple. everyone knows how pricy that stuff is. well my total was like $120 and some odd number. well i go back to the house and take the pan off and start gettin to work. after 4hrs of hard work and thinkin im done. i drive to the gas station to fill it up. well once i get back i look under tha truck and notice im still leakin. so i pop the hood, and notice the crankshaft pulley is wobling really bad. so i pretty much slam hood and go inside to cool off. turns out it wasnt the oil pan, money wasted. and now its lookin like im gonna need a new crankshaft and im not doing that. so i guess a new motor. god, what i do for my tacoma. :(
  2. Aug 27, 2010 at 1:42 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    neeed new truuuuck :drool:
  3. Aug 27, 2010 at 1:50 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Cranshaft pulley loose, Are you sure bolt did not come off? Did you try tightening ?
  4. Aug 27, 2010 at 2:23 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Check a few things before just assuming you need a new motor. Check the front crankshaft seal. Maybe the pulley came loose and you have a bad CS seal? Just check the small things first before dropping money into a new motor.:)
  5. Aug 27, 2010 at 2:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah sounds like the bolt backed out and now your pully is wobbling around. Also your crankshaft seal is probably leaking. When was the last time the T belt was done?
    edit, nevermind, you have a 4 cyl. This will not be a very difficult job.
  6. Aug 27, 2010 at 2:40 PM
    travis9287
    Travis
    Sylacauga, Alabama
    Big ol POS
    yes i tried tightning it and it was tight
  7. Aug 27, 2010 at 2:41 PM
    travis9287
    Travis
    Sylacauga, Alabama
    Big ol POS
    were gonna get things checked out before we invest ina new motor. I did the timing chain about a year ago.
  8. Aug 27, 2010 at 2:50 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    What 4cyl do you have the 2.4 or 2.7? And any abnormal engine noise? If its wobbling I wonder if that could mean bad harmonic balancers?
  9. Aug 27, 2010 at 2:52 PM
    travis9287
    Travis
    Sylacauga, Alabama
    Big ol POS
    It's a 2.7, it kind of nocks a little bit, but not so much when in higher RPM's. but i have no clue. i have never had this happen.
  10. Aug 27, 2010 at 3:10 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I dont have a 4cyl but if the crank was wobling like you said, you would know it because the whole motor would sound really ANGRY when it was running, if it ran at all. Dont throw in the towel, check to make sure crank pully is torqued down, and did you hit something to warp/bend pully? Also if pully is not seated or square are your belts showing signs of extreme wear? Also causes seal wear. Just remember the crank is the heart of your motor, bad crank is equal to low oil pressure. GOOD LUCK
