Well... My truck is leaking oil now.
Discussion in '1st Gen. Tacomas (1995-2004)' started by brettb, Jun 23, 2011.
  1. Jun 23, 2011 at 11:36 AM
    brettb
    brettb [OP] Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Talk about a major blow. I was over at my friends and we were fixing his truck and I went back in mine, dropped something and then saw a good size puddle of oil beneath my truck. My poor girl:( and yeah its leaking bad for oil.
    I'm pretty sure it happened that day because I didn't notice any the day before, and I was parked in the driveway so it would have been easily noticeable. I did go offroading like 3 days before, but I hardly did anything, just went through one puddle, and it wasn't too shaky.
    Soooo.... What do you think? I honestly cannot find where its leaking from but there is a lot of oil on the front side of the transmission. I really hope its just a blow gasket.
  2. Jun 23, 2011 at 11:43 AM
    toy.tech21
    toy.tech21 Active Member
    Evan
    Lakewood CO
    2008 Doublecab 6 speed
    K&N intake, URD short throw shifter, toytec boss front coilovers, old man emu dakars, led's in gauge cluster, dome and map light led's
    That sucks man. Is it engine oil or transmission fluid? Coming from the front transmission area sounds like maybe a rear main seal or front transmission pump seal, you should be able to see it mainly leaking from between the transmission and engine if its either one of those.
  3. Jun 23, 2011 at 11:44 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Not enough info provided. Are you sure you didn't park over some one else's oil mess? What to you see under the truck and where is the leak coming from? Year and engine?
  4. Jun 23, 2011 at 11:49 AM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Definitely between the transmission and engine. And yes is was engine oil, could see from the oil on the ground i needed a oil change anyways:rolleyes:
    Definitely my oil. I sat down there for 5 minutes and at least 3 drops came off my truck. Thats a good rate for engine oil.
    I think its coming from somewhere above the transmission, I was just saying I saw some on it to give a referrence where its leaking.
  5. Jun 23, 2011 at 11:52 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Clean everything up with brake cleaner or engine degreaser, then either wait and see or spray with talc leak detector.
  6. Jun 23, 2011 at 11:56 AM
    toy.tech21
    Evan
    Lakewood CO
    Ya man theres not a whole lot on that engine above the transmission that would leak that much oil unless you had one wicked valve cover leak. Its not uncommon for those rear mains to leak. I believe there might also be a breather tube with a breather that sits right about the transmssion. Maybe when going through the puddles its possible it might have gotten glogged up.
  7. Jun 23, 2011 at 12:07 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Thank you sir. I will plan on doing that today.
    Thanks for the info man I think i'll try to find out where its leaking from. When I first saw oil I thought for the worst, as in cracked engine block or something similar.
  8. Jun 23, 2011 at 12:16 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Okay so I just checked again and it looks as though its the seal between the transmission and what ever comes next, as in closest side to the engine.
  9. Jun 23, 2011 at 12:43 PM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    rear main is between the back of the engine and the front of the tranny.
  10. Jun 23, 2011 at 12:58 PM
    toy.tech21
    Evan
    Lakewood CO
    Yup sounds like a rear main leak man. Glad that i could help a little, good luck and i hope u get it all fixed up.
  11. Jul 13, 2011 at 3:13 PM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Update: As weird as it sounds... It's not leaking anymore. It definitely was oil when it was leaking and it leaked for a few days. And no its not empty or anything I checked it everyday and its full right now. Its super strange
  12. Jul 13, 2011 at 5:20 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    what was your ambient temperature outside when it started leaking?^
    I'd do a rear main seal anyways...just a good thing to be done on high mileage.
    When I put a new transmission in my truck..I did it..so I didn't have to pull transmission again;)
  13. Jul 19, 2011 at 2:26 AM
    brettb
    Brett
    Laramie, Wyoming
    '99 Tacoma
    I heard it would be like like ~$1000 to do though because you had to take pretty much everything out to get it? (engine,transfer case, tranny, driveshaft ect)
