Welp I just did something incredibly stupid.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackSeven, Mar 24, 2012.
  1. Mar 24, 2012 at 8:14 PM
    BlackSeven
    BlackSeven [OP] Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    Was putting my add-a-leafs in and forgot the shim after I bolted the spring pack back together. Then I cut the goddamn bolt off.
    So, now I need to head out to the hardware store in the morning and buy a new bolt.
    Derp Derp.
    The front looks awesome. The toytec ultimate lift has been great, and easy to install except for the UCA bolt.... Had to do some trimming on the sheet metal to get it out on the passenger side, only had to bend it a little on the driver side. Oh and I killed my dremel as well while cutting some sheet metal out of the way.
    Will post a build thread once I'm done. Next weekend come the 4.88's and locker.
  2. Mar 24, 2012 at 8:16 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How do you know you need the axle shims before you install your lift ?
  3. Mar 24, 2012 at 8:21 PM
    BlackSeven
    Maryland
    The instructions say if the shims are included in the kit, use them. So I put them in.
  4. Mar 24, 2012 at 8:23 PM
    BlackSeven
    Maryland
    285/70/17 duratracs and I had ECGS Build me a couple diffs, rear is going to have an ARB, front will be open.
  5. Mar 24, 2012 at 8:31 PM
    BlackSeven
    Maryland
    Yes, total price with core charges was 2100 ish + 155 for the small ARB compressor. That included the new sleeve bushing to deal with vibrations on the drivers side of the front diff.
  6. Mar 24, 2012 at 8:36 PM
    OZ-T
    Peter North
    British Columbia
    Interesting
  7. Mar 24, 2012 at 8:43 PM
    BlackSeven
    Maryland
    look at the last page and read step 16.
    Is it saying that the shim should be bolted in with the spring pack bolt or is it saying that the head of the spring pack bolt should go into the shim?
  8. Mar 24, 2012 at 8:49 PM
    OZ-T
    Peter North
    British Columbia
    The shim goes between the leaf pack and the axle , the centre pin goes through the hole in the shim and into the axle
  9. Mar 24, 2012 at 8:50 PM
    BlackSeven
    Maryland
    I'm putting the diffs in myself, that's pretty straight forward.
  10. Mar 24, 2012 at 8:56 PM
    hamsterhater
    hamsterhater Well-Known Member
    long island
    11' dc mag grey taco
    level kit- exhaust -cai n-fab light bar-4 piaa 6"new hood w/scoop
    hardend bolt:)
  11. Mar 24, 2012 at 8:58 PM
    OZ-T
    Peter North
    British Columbia
    OP , did your AAL come with a new centre pin ?
  12. Mar 24, 2012 at 9:10 PM
    BlackSeven
    Maryland
    Yes I put the new center pin through the overload, add a leaf, and two top leaves, but didn't put it through the shim.
  13. Mar 24, 2012 at 9:13 PM
    OZ-T
    Peter North
    British Columbia
    Did it have a collar on it at the non threaded end ?
  14. Mar 24, 2012 at 9:25 PM
    BlackSeven
    Maryland
    To the right is the stock pin. The rod that's in the shim is what I cut off of the new bolt after I put it in the spring pack. And there is the shim with a relief for the pin at the end of the bolt.
  15. Mar 24, 2012 at 9:30 PM
    OZ-T
    Peter North
    British Columbia
    You see the round , non threaded " head " of the stock centre pin ?
    This portion will not be longer with a new pin , the head goes through the shim and is meant to drop into a hole in the axle side .
    The only way to make this end longer is with a collar .
    Is there enough of the head sticking through the pack to put the shim between the leaf pack and axle and still securely seat in the axle ?
  16. Mar 24, 2012 at 9:33 PM
    OZ-T
    Peter North
    British Columbia
  17. Mar 24, 2012 at 9:41 PM
    BlackSeven
    Maryland
    No the head of the new pin will not fit through the hole in the shim, but the threaded shaft fits through perfectly so I'm assuming that's the way that it was supposed to be assembled.
  18. Mar 24, 2012 at 9:43 PM
    OZ-T
    Peter North
    British Columbia
    Interesting .
    In that case you are correct , and a longer pin is what you need .
    Sorry for the confusion
  19. Mar 24, 2012 at 9:47 PM
    BlackSeven
    Maryland
    Are centering pins typically something that can be picked up at an autoparts store or will a hex cap bolt likely do an ok job as a centering pin?
  20. Mar 24, 2012 at 9:51 PM
    OZ-T
    Peter North
    British Columbia
    The head needs to be round and the same size as the centre pin head in order to seat in the axle
    An auto parts place may have them , I got a pair and a set of collars at a local spring shop
