Welp. I'm screwed
Discussion in '1st Gen. Tacomas (1995-2004)' started by PyrettaBlaze, Jun 9, 2016.
  1. Jun 9, 2016 at 3:43 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It's CMA fest and traffic sucks so I'm staying late at work specifically for this reason haha
  2. Jun 9, 2016 at 6:46 PM
    PyrettaBlaze
    PyrettaBlaze [OP] Well-Known Member
    Kristopher
    Salt Lake City, UT
    1996 Tacoma 2.4
    Hahaha these comments were GOLD to come back to.
    Replaced the fuse. Truck is now mobile again.
    Will only plug in gauge cluster when unit is off. Lesson learned.
    Thanks guys!!
  3. Jun 9, 2016 at 7:19 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Something else had to have happened. Clusters draw like .3 amps at most.. with the illumination turned off. Plugging something in does not causes fuses to blow unless that something draws more current at startup than the fuse is rated for. A cluster is not blowing an ignition fuse unless there was a short. I *think* an ignition circuit might run to the cluster, but I havent looked at the diagrams in a while.
    jmaack likes this.
  4. Jun 9, 2016 at 8:04 PM
    PyrettaBlaze
    Kristopher
    Salt Lake City, UT
    1996 Tacoma 2.4
    Well, it happened while the vehicle was running..
    If it happens again I'll do some more digging.
  5. Jun 10, 2016 at 12:01 AM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Try cleaning your connections to the battery and grounds. This happened to me and that was an easy fix
  6. Jun 10, 2016 at 4:37 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Two wires touching together or a wire touching ground are likely causes. Make sure everything is taped up well.
  7. Jun 10, 2016 at 9:11 AM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    It happens. I blew the ECU fuse on my GFs camry while hooking up a homelink mirror.
  8. Jun 10, 2016 at 5:24 PM
    PyrettaBlaze
    Kristopher
    Salt Lake City, UT
    1996 Tacoma 2.4
    Awesome guys.
  9. Jun 10, 2016 at 5:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    The lesson here is not to have stuff running when dinking with significant wiring.
    Better yet, pull the ground off the battery and have no risk at all.
    Saves a lot of headaches.
  10. Jun 10, 2016 at 6:46 PM
    PyrettaBlaze
    Kristopher
    Salt Lake City, UT
    1996 Tacoma 2.4
    Lesson learned!
