Welp. Some not so good news. Bad roof damage... (Not as bad as originally thought)
Discussion in '1st Gen. Tacomas (1995-2004)' started by CruisD64, Feb 15, 2023.
  1. Feb 18, 2023 at 4:44 AM
    #41
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    THanks, nice rig too. The 60 series are bigger than the 80 series...lol But mine has been out of commision for a while, bad timing chain guides. Requires the engine be pulled to replace them. Please parts are expensive. But yeh 160k blown motor is probably the head gasket unless it's blown on the lower end. I bought mine in 2011 for $5k. If it was running today I bet I could get 10-15k for it.
  2. Feb 20, 2023 at 5:47 AM
    #42
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Amazing it still caved in even with the roof rack.
    Really does give you an appreciation for automotive engineering when you think about the huge range of conditions any mass produced vehicle is expected to endure.
  3. Feb 20, 2023 at 12:23 PM
    #43
    TragicBronson
    TragicBronson Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    That Prinsu might have kept this situation from being a worse!
  4. Feb 20, 2023 at 12:33 PM
    #44
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Maybe a trimmed piece of plywood up there would have helped.
    CruisD64[OP] likes this.
  5. Feb 20, 2023 at 1:13 PM
    #45
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Yes and leave it on there overnight.... then after it have stopped snowing, remove the plywood.
    Put waterproof coat on the plywood. Once it dries, then place it on the roof, strapped down so the wind won't blow it off.
  6. Feb 20, 2023 at 2:14 PM
    #46
    Taco y mas
    SoCal
    Tacoma TRD Sport
    None
    Yes, cause the roof rack maybe could've helped if there was some ply up there. In my opinion, the rack can't help if the object falls through.
  7. Feb 20, 2023 at 2:28 PM
    #47
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Am I wrong in thinking something covering the rack would actually make it worse? With no covering the weight of the snow is fairly equally distributed but if there was a piece of plywood or whatever all that weight is shifted to the mounting points. Yeah they're near the stronger points of the cabin shell but still much smaller load distribution area.
  8. Feb 20, 2023 at 9:44 PM
    #48
    Taco y mas
    SoCal
    Tacoma TRD Sport
    None
    Worth a try after that debacle.
  9. Feb 22, 2023 at 4:36 PM
    #49
    CruisD64
    CruisD64 [OP] Well-Known Member
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Line-X, LED Gauges, Bluetooth Stereo, TracRac, OME 2.5 Lift, Relentless Fab rear bumper, Shrockworks front. Bleh. So much good stuff.
    That's exactly what I thought of after the fact. The plywood. I'm going to do that. I just never thought this would happen. This truck ain't moving until spring but I won't be so careless going forward. If there is a huge storm I'll come back up and clean it off.
  10. Feb 22, 2023 at 4:44 PM
    #50
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    The plan is going to be to take it to get an estimate first after it's out. Then move on with insurance if the repair is reasonable. Otherwise I'll either repair it myself eventually or just have it done out of pocket if there is any risk of it being totaled.
    Thoughts?
  11. Feb 22, 2023 at 4:46 PM
    #51
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Rack caused most of he damage, take it off lay on you back with your sneakers and push out then put the rack back on.
  12. Feb 22, 2023 at 4:50 PM
    #52
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    It's mostly pushed out now just by hand. There are a few creases that are causing it to spring back when I push. The more and more I look at it I think it's fixable. I could live with it as it but I hate body damage. Especially having done bodywork for personal projects most of my life.
    SR-71A likes this.
  13. Feb 22, 2023 at 4:52 PM
    #53
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    PS - The roof is pretty much the only thing I never liked about gen 1's. Like everytime I washed it I could feel that it was just thin sheetmetal. Gen 2's and 3's have way more reinforced roofs.
  14. Feb 22, 2023 at 4:59 PM
    #54
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    You mean the huge storm that's coming in now? Mammoth forecast is batshit crazy. Easily 5 ft in the next 4 days.
    El Taco Diablo likes this.
  15. Feb 22, 2023 at 5:11 PM
    #55
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    I guess. Luckily this time I'll be coming back up here in a few weeks so I'll be able to clean it off before it gets too bad.
  16. Feb 22, 2023 at 7:53 PM
    #56
    TAZMINATOR
    2017 Tacoma
    Rack didn't cause the damage... it was the snow which later became ice in very cold weather. The water leak through between crossbars which became icicles. OP had deep snow which is too much weight. Just like big ice block sitting on his roof.
    I have rack on mine and had 6 inches of snow storm here but no damage yet.
  17. Feb 22, 2023 at 8:30 PM
    #57
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Just an update. My uncle was able to pull a favor with one of his buddies and he's going to use a loader to dig a path out for my truck tomorrow at 8AM. So she'll be out. And I'll be back up here in 2 weeks to take her to SF and fully assess the damage.
    Icicles is exactly the reason. I believe I mentioned that in an earlier post.
    SR-71A likes this.
  18. Feb 22, 2023 at 8:49 PM
    #58
    TAZMINATOR
    2017 Tacoma
    That's good. Hope things go well for you.
  19. Feb 22, 2023 at 9:09 PM
    #59
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Thanks! I'll make sure and take photos of how much snow is actually moved tomorrow. And of course a snow-free truck (as much as possible...) :)
  20. Feb 23, 2023 at 12:21 PM
    #60
    CruisD64
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    She's out!!! Found another dent, though... suspiciously where a previous claim was. Shoddy body work? You can see the bondo cracked.
    THatt and SR-71A like this.
