Welp.....Stim $$ spent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knute, Mar 17, 2021.
  1. Mar 17, 2021 at 9:24 AM
    Knute
    Knute [OP] Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Spent a chunk of the stim check on repair parts.
    Serp belt, pulleys and tensioner.
    U-joints front & rear shaft.
    Carrier bearing.
    This is the last of the 100 kmile maintenance the truck is needing. These should eliminate the belt howl and the low speed shudder.
    Dealer wants $1150 to do the work to replace the Serp belt system. So, I'm supplying the labor, the parts coming from RockAuto. I didn't bother with a quote for the drive shaft work.
    The remainder will be spent on the home.
    Hopefully, when the work is done on the home, some $$ will be left so I can replace the speakers.........
    In one pocket.....out the other pocket. Life.
  2. Mar 17, 2021 at 9:31 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Hey, repairs/maintenance items for "free"... can't beat that!
    User Name01 and whatstcp like this.
  3. Mar 17, 2021 at 9:36 AM
    Knute
    "Free" is debatable.
    I'm sure we will see an increase in fees around April, 2022.
    Ain't nuttin' free.
  4. Mar 17, 2021 at 10:27 AM
    LongTaco15
    LongTaco15 Active Member
    Round Lake, IL
    15 TRD Sport DCLB
    Bone Stock
    $1150 for the serpentine belt?!! Crazy...
    dustinJ likes this.
  5. Mar 17, 2021 at 10:31 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My mechanic replaced my serpentine belt and I'm pretty sure it was in the $120-$150 range for parts and a labor...? Damn stealerships...
  6. Mar 17, 2021 at 10:35 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Belt and idler pulleys are not really a big deal. The tensioner is a bit more involved, if I recall correctly.
  7. Mar 17, 2021 at 10:45 AM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
    I spent the entirety of mine paying the principle down on my truck. Only $2,200 left!
    wyotaco801, ToxicTwin, Rezkid and 5 others like this.
  8. Mar 17, 2021 at 11:00 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Hence the quotes. We'll ALL be paying for that "free" eventually.
  9. Mar 18, 2021 at 7:08 AM
    Knute
    ok. To clarify.
    The entire Serp belt system is being replaced. Belt, 3 idlers and the tensioner. Using the Gates kit from RockAuto. Parts arrive Friday. Work begins Saturday morning. I'm planning this as the only task for the weekend.
    The tensioner is the complex replacement. Mostly due to having to dig under the Alternator and the A/C compressor working thru the LH front wheel well.
    So, it is not a "simple" belt only task.
  10. Mar 18, 2021 at 7:55 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Why not just replace the tensioner pulley itself? That'll save you an hour or 2 and maybe a knuckle or 2 as well.
    I've replaced idlers, but haven't touched the tensioner. That bearing sounds good with a stethoscope.
    That being said: I replaced the idlers from under the truck. Twas an easy job requiring only 1 or 2 combination wrenches. I took tension off the belt and took the belt of off the PS pump. Also, the belt runs close to itself on the PS pump side. Pay attention when snaking the belt around everything or it'll scream like a banshee when cold.
    Ask me how I know...:anonymous:
  11. Mar 18, 2021 at 8:13 AM
    Knute
    @Larzzzz I get where you are coming from.
    That path was considered. I know the truck's history. 110 kmiles, lived on gravel roads, limited maintenance......... Also, there is a belt related howl coming from one of the idler/tensioner. Another consideration, the tensioner spring, like all springs, can take a set and weaken over time with constant load and heat cycles.
    So, I'll be in there doing the work. My labor just costs a bit of time, a bloody knuckle or two and some bad language. Plus, I'd be immensely aggravated to replace the pulley, then have the tensioner fail in the dead of winter. Critical things always fail based on Murphy's rules.
    Larzzzz likes this.
  12. Mar 18, 2021 at 8:47 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I got that same kit for my 2012 before looking up the tensioner replacement procedure. I ended up skipping the tensioner and just did all the idlers. I didn't have any noise, just 90k on the truck and figured a new belt was a good idea, and the tensioner seemed fine. Figured I'd wait until something else broke requiring a bigger teardown and swap it then. At the time, I also had a timing belt replacement to do on a 4.7 V8 and figured I'd spend my time getting that right.
  13. Mar 18, 2021 at 8:53 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Like pay day. Its more of a middle man day than anything:facepalm:
  14. Mar 21, 2021 at 6:05 PM
    Knute
    Started the serp belt system replacement today. Began at 10:30 am. Finished at 4:30 pm.
    The video of this work on an FJ leaves out several details which make the Tacoma more difficult.
    Digging down to the A/C compressor is pretty straight forward following the video. After that, it becomes a different creature.
    The A/C mount bolts are very shrouded, occluded and difficult to access. Many blue words, various tool configurations, a pneumatic impact........the bolts finally gave up. Tensioner replace was pretty straight once the A/C was dismounted. The idlers were no issue. Let me say, bolts that haven't moved since '06 and 100+ kmiles are stubborn cusses.
    Belt on and routed, everything assembled. No left over parts. The howl in the front is gone.
    Tomorrow, I'm expecting U-joints. Then onto the driveline shudder elimination.
  15. Mar 22, 2021 at 11:27 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Good job! That was my concern, looked like a PITA to do all that for just a belt refresh when I wasn't concerned that the tensioner needed a refresh.
    Have fun with the u-joints! They aren't that bad if you have a vise or the proper tools.
