Went a little crazy with adding D-rings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Apr 22, 2012.
  1. Apr 22, 2012 at 8:25 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    I have been hauling the bike to quite a few track days recently and constantly find myself wanting to tie down a gas can or ramps or other gear. I went to Home Depot and picked up these mini D-Rings, that are rated for 30 lbs - adequate to strap down small stuff. Bought a 10 pack and went a little crazy :D
  2. Apr 22, 2012 at 8:30 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    i just dont know if i would trust driving behind you lol hit a bump and break one of those d rings or head off the bolt and there goes your load
  3. Apr 22, 2012 at 8:32 AM
    Rushbrook
    Rushbrook Well-Known Member
    Wow...lol. Wanna help me move?
  4. Apr 22, 2012 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Those D rings dont look very strong.....
  5. Apr 22, 2012 at 8:40 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  6. Apr 22, 2012 at 8:40 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    X2
    Those bolts are only screwed into plastic inserts I believe. Not the safest point to secure weight to.
    Frank
  7. Apr 22, 2012 at 9:11 AM
    xxaarraa
    Geez TW people! It's not like I am holding up my bike with those "D Rings" These would be used to strap down lightweight aluminum ramps (~20-30 lbs?), gas can (~20-30 lbs?), gear (~10-20 lbs?) etc. Supposedly they are rated for 30 lbs each...
  8. Apr 22, 2012 at 9:20 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Perfect for all your 30 lb items you will transport.
  9. Apr 22, 2012 at 9:21 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Just to have loops to tie shit to keep from sliding around. How are they anchored? Just screwed into the bed liner?
    Scratch that, I see you used existing bolts and screws.
  10. Apr 22, 2012 at 9:28 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    ^ it's still kinda scary. do you realize how easily those screws on the tailgate can strip out... or fail. the screws are anchored by soft plastic...
    also, with the tailgate bouncing around, i wouldn't trust it.
  11. Apr 22, 2012 at 9:30 AM
    Alex88
    Alex88 Well-Known Member
    Alex
    El Cajon, CA
    2010 DCLB Sport
    those existing bolts and screws are going in to plastic clips, not the tailgate.
  12. Apr 22, 2012 at 9:37 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    The d-rings are rated for 30lbs. The screws you have attached them to your tailgate with were never intended to be load bearing.
    THAT is the problem.
    If your aluminum ramps come flying off your tailgate at 70 and impale the driver behind you, you're going to have some immediate and serious problems. You might get lucky with this time and time again. It's if you don't that I'm worried about.
    Buy a bed extender or roof rack. Stuff like this is why they exist.
  13. Apr 22, 2012 at 9:38 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    xxaarraa,
    The threaded inserts inside the tailgate are plastic and VERY easily stripped out, nor would I trust the "D" rings you purchased. You stand a very good chance of having the ramps come loose and causing an accident for anyone following behind you.
  14. Apr 22, 2012 at 9:48 AM
    GotLift37
    down south
    07 4Runner 4WD
    please do not use those unless you plan on killing someone in the process
  15. Apr 22, 2012 at 9:58 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I don't see any problem here, as long as the tailgate gets closed after the ramps get strapped down. if you are leaving the gate down, thatis just asking for problems.
  16. Apr 22, 2012 at 10:01 AM
    jandrews
    I'm pretty sure the tailgate is down to fit the bike in the bed, and there's no room to pack the extra equipment around it.
    What the OP really needs in that situation, if that is the situation, is a bed extender.
  17. Apr 22, 2012 at 10:06 AM
    Afwrestler1986
    Johnstown, NY
    Yeah i figured that, was giving him a chance though.
  18. Apr 22, 2012 at 10:08 AM
    wolftree
    Rick
    Ohio
    From what I could tell about the "D" rings, they look like something for holding pictures on walls, not securing a load in a moving vehicle.
  19. Apr 22, 2012 at 10:09 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Good point... "if" he is planing to use this setup with the gate down he should have went with a bed extender... if not then he should have went with a little common sense... which would have led back to the bed extender.
    Frank
  20. Apr 22, 2012 at 10:10 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    I would not be using the tailgate bolts to secure any kind of load at all.
    I've got two that are installed, but "stripped" to the point that they won't snug down after being removed twice... once to install my pop-lock, and once to install my BedRug.
    Replace the plastic inserts with some Riv-Nuts and matching screws and you'll have something that's at least as strong as the tailgate sheetmetal... which still isn't nearly 30lbs.
    No way I would drive with that stack of ramps back there.
