Went mudding got a prob now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TG8, Oct 1, 2012.
  1. Oct 1, 2012 at 6:29 AM
    TG8
    TG8 [OP] Well-Known Member
    Trey
    Laredo, Texas
    2011 Tacoma Trd Sport 4x4
    STOCK STOCK STOCK SUCK STOCK STOCK WeatherTech Floor Mats All-Weather throughout the truck Smittybilt Bull bar with Hella 500 Series Halogen Driving Lamp (2)
    Okay so this past weekend in south texas it rained and i went a little mud crazy. So when i was driving on the highway after I went mudding my truck was vibin horribly like the whole truck was shaking. Ive taking it to get a car wash and I power washed it and it still vibing horribly anyone with any solutions fast? My daily travel to college is all highway im kinda scared of what might happen
  2. Oct 1, 2012 at 6:30 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    you probably have mud caked inside your rims, making the wheels off balance.
  3. Oct 1, 2012 at 6:32 AM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    ^^ This
  4. Oct 1, 2012 at 6:32 AM
    TG8
    Trey
    Laredo, Texas
    i power washed all four wheels, maybe still more? Ive gone crazy like this a lot going through mud but its NEVER vibed like this
  5. Oct 1, 2012 at 6:33 AM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    x3. you let it sit and the mud dried on the inside of your rims throwing your balance off. hose em down good
  6. Oct 1, 2012 at 6:34 AM
    TG8
    Trey
    Laredo, Texas
    alright thanks buds!!!
  7. Oct 1, 2012 at 6:34 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    could be literally dozens of things....start with the obvious like off balanced wheels and work your way up to the driveshaft
  8. Oct 1, 2012 at 6:36 AM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yep may need to crawl under with a plastic scraper. That's why mud sucks.....
  9. Oct 1, 2012 at 6:52 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Also after you spray the wheel off good, make sure your weights are still on the rims. I've seen em come off
  10. Oct 1, 2012 at 7:00 AM
    TG8
    Trey
    Laredo, Texas
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    there is always the angel and the devil on the my shoulder every time I hit it. The angel tells me dont do it you need to a lot of hard work after and something might ruin your truck! The devil says FLOORRR ITTTTTTTT!!! devil wins most of the time :(
  11. Oct 1, 2012 at 7:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is a good point also. Even though the mud might be gone, it's possible you lost some wheel weights in the process.
  12. Oct 1, 2012 at 7:03 AM
    XXXX
    sKiP
    05 Prius
    this is why when I get a tire mounted:
    1) the weights go on the inside (no rim mounts)
    2) I dremel P1, P2, D1, D2 on each wheel (on the inside) and mark how much weight each took
  13. Oct 1, 2012 at 7:04 AM
    Larry
    Larry CARL
    CARL
    maybe you need spiritual enlightment.
  14. Oct 1, 2012 at 7:09 AM
    TG8
    Trey
    Laredo, Texas
    maybe :(
  15. Oct 1, 2012 at 7:09 AM
    TG8
    Trey
    Laredo, Texas
    i noticed im missing a weight in the right rear rim unless there shouldnt be one there but ever other rim has one so...
  16. Oct 1, 2012 at 7:14 AM
    TG8
    Trey
    Laredo, Texas
    never mind found it on the inside turns out all the other weights are on the outside but the rear right wheel
  17. Oct 1, 2012 at 7:15 AM
    Larry
    Larry CARL
    CARL
    give it a try, it will change your life.
    the evil one is always at work trying to own your soul. having the tools to fight his evil spirit is a blessing.
    there is mercy for all of us, but you have to seek it.
  18. Oct 1, 2012 at 7:18 AM
    shemp
    shemp Well-Known Member
    In a perfect world where every rim and tire come off the manufacturing machine in perfect balance, you wouldn't need any weights at all.
    As it happens, sometimes you get lucky and the whole thing is just perfect without weights. Rotate the tire 20 degrees on the rim though, and it could shake like a beast.
    Just saying that maybe that wheel was perfect without weights. I wouldn't consider a lack of weights to indicate that something is wrong.
    You can check the rim carefully -- the installation of weights always leaves marks on the rim. If there are no marks anywhere on the rim indicating that a weight was present, then a weight was never present.
    FYI: other than wheel balance, you could have blown a bearing, a u-joint, or a CV joint. Those would also cause some pretty good shaking. Mud does not mix well with any of those.
  19. Oct 1, 2012 at 7:18 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  20. Oct 1, 2012 at 7:40 AM
    r3dn3ck13
    r3dn3ck13 Well-Known Member
    Clayton
    Lynden
    White 2007 DCLB TRD Sport
    6 in fabtech, 35's
    I had the same thing. But I screwed a lot up when I did it. Blew up drivers side wheel bearing. Passenger side went out a month later. All four ball joints and drivers cv axle. :) hope it was just some mud in your wheel! You don't want to have to deal with all that I had too!
