Went over to the dark side...bodylift.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Jun 22, 2017.
  1. Jun 22, 2017 at 4:17 AM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Swore I never would but I ordered a 1" body lift from 4crawler offroad (Roger Brown) last night. Great customer service and he answered mutiple emails within minutes.
    Truck is already lifted 3 inches with OME 883s. I've been rocking out 33" tires for 8 years now but it's time to step up the game to 35's. Being locked front and rear the biggest thing that stops me now is lack of ground clearance so 35's will help a little. Plus I'm disappointed I haven't broke a front cv yet with my front locker. Some bigger tires should fix that:rolleyes:.
    I know I'm still going to have trimming to do on the firewall, cab mounts and possibly still the fenders even with the 1" lift but I'm hoping it will minimize the need for it.
    Looking forward to receving the lift and getting this project rolling.
    Dalandser and ChadsPride like this.
  2. Jun 22, 2017 at 4:29 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sounds like one of the few reasons for needing a body lift that you can justify lol.
  3. Jun 22, 2017 at 4:30 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Plenty of wheeling members run 1" BL's for more clearance
    Should be good to go!​
    Alfred, Benzdriver81, Coot83 and 2 others like this.
  4. Jun 22, 2017 at 7:08 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Another side-benefit to a 1" BL, is easier access underneath to things like bell-housing bolts.
  5. Jun 22, 2017 at 7:34 AM
    Ktaco
    For sure. This was another reason I went for it. I put a new clutch in a few months ago and that extra 1" would have been nice.
    ChadsPride likes this.
  6. Jun 22, 2017 at 8:28 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    Planning on putting a 1" on mine soon
    Ktaco[OP] and ChadsPride like this.
  7. Jul 5, 2017 at 7:41 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Do you need anything extra to do the 1"? I've considered doing this but not sure on what all is needed
  8. Jul 5, 2017 at 7:50 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    A extra inch could mean a world of difference depending on where it was at.
  9. Jul 5, 2017 at 9:01 PM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    :amen:
  10. Jul 5, 2017 at 9:05 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    I'm also wondering. New brake lines or at least extending the current ones? Anything else?
  11. Jul 6, 2017 at 1:50 AM
    Ktaco
    I haven't got my lift yet, should be another week or so. Off the site I ordered from you can customize your lift to what you need. They have brackets for everything much of which is not needed on the 1" lift.
    I went with a basic setup. The 1" lift blocks, front and rear bumper brackets so there is no gap between body and bumper, a steering shaft extension, and bed spacers that support the bed cross memeber so I can still haul "heavy" loads. I also chose to upgrade all my hardware to something a little stronger but really for 1" I doubt you would have to.
    The radiator will hit the bottom of the shroud after being lifted which is a easy fix as the bottom piece of the shroud just unclips. As for brake lines and other cables there is sufficient slack to allow for a 1" lift.
  12. Jul 6, 2017 at 7:30 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Read the Roger Brown (4Crawler) install writeup. It covers everything...
    In addition to Ktaco's input, your fuel filler neck will need some loving - at least remember to remove the fuel cap before lifting the bed. I essentially got the same 'parts' as Ktaco, opting out on the bumper brackets. Easy install. Loosen all bolts, but do not remove the them. Lift one side, then the other. Do either the cab or the bed first - I did the cab first. It will help to have a second set of hands.
  13. Jul 6, 2017 at 7:32 AM
    Ktaco
    Did you upgrade to the "heavy duty" hardware as well?
  14. Jul 6, 2017 at 7:32 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    when you venture into armor is when you have issues with body lifts. i know a few locals having to fab brackets to get their stuff to line up without gaps. good luck with install, its pretty straight forward
  15. Jul 6, 2017 at 7:36 AM
    pray4surf
    Rick
    Oceanside, CA
    I did - it's been 10 years and nary a problem
  16. Jul 6, 2017 at 7:44 AM
    Ktaco
    Do you recall if you had to drill out the stock washers to accomadate the larger bolts?
  17. Jul 6, 2017 at 12:14 PM
    pray4surf
    Rick
    Oceanside, CA
    Nope, can't recall ;)
  18. Jul 6, 2017 at 12:24 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Il be doing 1" aswell.
  19. Jul 6, 2017 at 4:19 PM
    4crawlin
    4crawlin Active Member
    01 TRD Tacoma
    I'm considering Daystar one-piece polyurethane bodymount bushings that have 1" lift
  20. Jul 6, 2017 at 4:26 PM
    Ktaco
    I seen the daystar kit but decided to go with the 4crawler offroad kit because it seems to be thoroughly tested by the offroad community.
    That's not to say the Daystar is a bad choice; there just wasn't enough "reviews" on it for me.
