Went through water... now issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dank24, Apr 16, 2018.
  1. Apr 16, 2018 at 6:37 PM
    Dank24
    Dank24 [OP] Well-Known Member
    3rd gen OF
    So, I took the truck through puddles and a water crossing. The water crossing was prob a 40-45 second pass.
    Now the truck doesn’t have the pep/power, feels bogged down, and shifting is jumping all over the place. Feels as if it lost 1/3rd it’s power.
    It is not throwing any codes, the under carriage looks fine as I hosed everything off.
    Any ideas?
  2. Apr 16, 2018 at 6:40 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Have you checked the transmission fluid? Sounds like something is wrong in that area, but its sealed so wonder how water would have leaked in there.
    I would make sure you also get all the water out of the rear differential (like wipe the gears down). Next thing would be to check sensors although that should throw codes out. Other than that, did you change your engine oil just in case?
    Argo98 and Slashaar like this.
  3. Apr 16, 2018 at 6:43 PM
    Dank24
    3rd gen OF
    Yup, engine oil was clean. The rear differential had oil flushed through.
  4. Apr 16, 2018 at 6:44 PM
    FourBanger99
    FourBanger99 4 Banger Taco
    Bayne
    Birmingham
    2012 Black Tacoma 2.7 AC SR5 4x4
    Full OME Suspension CB Diff Breather Duratracs
    Your ecu is probably confused by the pace you where off-roading at so your shifts might be a little off. I could be wrong on that tho. Check your intake from the wheel well all the way to the air box to make sure there’s no blockage. You’ll also be able to tell how much water got into the air box. A little tip for increasing power is removing the secondary air filter in the box.
    tcjacado and Dank24[OP] like this.
  5. Apr 16, 2018 at 6:48 PM
    ZekeR7
    How many miles do you have on your truck?
  6. Apr 16, 2018 at 7:03 PM
    Dank24
    3rd gen OF
    5k
  7. Apr 16, 2018 at 7:04 PM
    Dank24
    3rd gen OF
    I will check this out tomorrow :thumbsup:
  8. Apr 16, 2018 at 7:05 PM
    Dank24
    3rd gen OF
    I’ve had Subaru’s that I was able to beat one more than this. I babied it, too.
    Fortunt1 likes this.
  9. Apr 16, 2018 at 7:07 PM
    tcjacado
    tcjacado Well-Known Member
    Also check that your radiator isn't all gunked up.
    Dank24[QUOTED][OP] likes this.
  10. Apr 16, 2018 at 7:10 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  11. Apr 16, 2018 at 9:28 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Is your air filter damp? If you sucked water vapors in the air intake you have a problem now...
  12. Apr 16, 2018 at 9:47 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    What? :confused:
    Don't drive in the rain then I guess
  13. Apr 16, 2018 at 10:00 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    You probably got water in the connector to the transmission. I would unplug and spray that out with electrical cleaner. If you get water in those connectors, it will make the transmission do all kinds of funny stuff.
    lynyrd3, OnHartung'sRoad and PROseur like this.
  14. Apr 16, 2018 at 10:10 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Wait! What? You took it off road! What were you thinking? Just because it says off road doesn’t mean you can drive off road! But seriously, let us know the solution.:thumbsup:
  15. Apr 16, 2018 at 10:37 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Hey Chewie- besides not driving in water o_O what is the best treatment of those connections that someone can do to protect them before driving through water?
    Yea, did the dif breather mod already as well, sorry if you didnt do it OP- perhaps now would be a good time for that too:
    https://www.tacomaworld.com/threads/differential-breather-mod-for-dummies-pics.15686/
    Slashaar, tonered and tcjacado like this.
  16. Apr 16, 2018 at 11:00 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Unless the breather mod was done, how else would water get in the diff?
    BillsSR5 likes this.
  17. Apr 17, 2018 at 3:31 AM
    Dank24
    3rd gen OF
    Is this the plug going to the transfer case?
  18. Apr 17, 2018 at 3:32 AM
    Dank24
    3rd gen OF
    Breather was not done prior. I didn’t know it was only 14-16” off the ground. Already ordered the parts from the dealer and picking them up Thursday
  19. Apr 17, 2018 at 6:17 AM
    BillsSR5
    bill
    2014 SR5
    the lesson here is don't buy a $50k truck and try to use it as a boat
    Argo98, DukesTaco, remgu2000 and 20 others like this.
  20. Apr 17, 2018 at 6:42 AM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    Unsure where exactly it's at. Should be somewhere on the transmission itself. I'm just talking from experience with a couple of older cars. Water getting into the connector can cause issues.
