Went through water... now issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dank24, Apr 16, 2018.
  1. Apr 17, 2018 at 6:44 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    usually the breather on a transmission or transfer case will be on top of the trans. under the shifter console area
  2. Apr 17, 2018 at 6:45 AM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Silicone spray would work to Help dissipate water. You could also wrap the base of the connector with self vulcanizing tape and work it up the connector. That may however trap water in there. I'd say try the silicone spray.
  3. Apr 17, 2018 at 6:52 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Everybody thinks their truck is a submarine.Water and new trucks with tons of electrical parts don't mix.
    TXpro4X4, TacticalTac0 and BillsSR5 like this.
  4. Apr 17, 2018 at 6:53 AM
    BillsSR5
    bill
    2014 SR5
    yes it says TRD Offroad, not USS Nimitz on the side of it
  5. Apr 17, 2018 at 7:22 AM
    Dank24
    Dank24 [OP] Well-Known Member
    3rd gen OF
    It should be able to go through 18” of water.
  6. Apr 17, 2018 at 7:23 AM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    at what speed? 40 knots?
    Lawfarin, KBOX, Gunshot-6A and 4 others like this.
  7. Apr 17, 2018 at 7:44 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    spray WD-40 on all electric connections before diving in!
  8. Apr 17, 2018 at 7:51 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    You need to use a special compound made especially for electrical contacts not silicone, wd40 etc. Look at corrosion-x.
    http://www.corrosionx.com/
    xxTacocaTxx likes this.
  9. Apr 17, 2018 at 7:58 AM
    Prinxace
    Prinxace Well-Known Member
    New England
    2017 Super White TRD OR DC 4x4
    I went through water just as deep when boston got flooded my truck is fine, check your connections again let them dry out. How long ago was this? have you drove it since? check the trans fluid too..
    TXpro4X4 and BillsSR5 like this.
  10. Apr 17, 2018 at 8:00 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    This made me lol.
    I hopped under my 18 to install some steps. Coming from an 05, I couldn't believe the amount of electrical under there. These trucks are definitely going to be pay to play vehicles. Hope you get it sorted out soon OP.
    lynyrd3 and Dank24[OP] like this.
  11. Apr 17, 2018 at 8:01 AM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    Something doesn't sound right. I would wash the truck really well and take to the dealer since you're under warranty. That amount of water should not have hurt anything.
    remgu2000, lynyrd3, BillsSR5 and 2 others like this.
  12. Apr 17, 2018 at 8:02 AM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    You can. I've had water fly over my hood from going into deep water and was fine. Definitely up to my cab when I settled in. 0 issues here.
    BillsSR5 and Dank24[QUOTED][OP] like this.
  13. Apr 17, 2018 at 8:06 AM
    Dank24
    3rd gen OF
    I’m taking it to be looked at Thursday. I will update
  14. Apr 17, 2018 at 8:09 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Come up flank!
    BillsSR5 likes this.
  15. Apr 17, 2018 at 8:14 AM
    #35
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Hearing other consumers jump to take the brands side and say that a truck is not meant to go through water up to the door sills is comical at best.
    These are capable trucks and at very least able to cross a slightly flooded street as they get in most states that get a decent amount of rain.
    I would jump to a different brand for safety reasons if my truck was ever not able to do a quick water crossing up to the bottom of my door. I’m on my 4th tacoma by the way and I don’t beat on them but I know what they are safely capable of.
    Guess some people only use their trucks to haul camping chairs to the soccer fields.
  16. Apr 17, 2018 at 8:33 AM
    #36
    Dank24
    3rd gen OF
    Sunday, drove it Monday and today as well. Still acting very weird and loss of power. No codes
  17. Apr 17, 2018 at 8:56 AM
    #37
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You may take this as a grain of salt. Why don't you try to remove battery cables for like 30minutes to reset everything . This might help
  18. Apr 17, 2018 at 9:12 AM
    #38
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Then flog it. Hard.
    BrokenMech likes this.
  19. Apr 17, 2018 at 9:13 AM
    #39
    Lt. Dangle
    Ohio
    I do similar stuff with my truck on a fairly regular basis and have no issues, so OP either got unlucky, or some placebo effect has taken place because these trucks will do what is described and shown no problem.
    ChronicTaco likes this.
  20. Apr 17, 2018 at 9:22 AM
    #40
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    You could try this, it would not hurt.
    As well as the connectors that were mentioned before
    You should check your trans fluid just in case, since there is a vent on top of it. .. Just remember there is a procedure about refilling the trans fluid
    lynyrd3 likes this.
