Went through water... now issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dank24, Apr 16, 2018.
  1. Apr 17, 2018 at 9:23 AM
    #41
    Prinxace
    Prinxace Well-Known Member
    New England
    2017 Super White TRD OR DC 4x4
    I'm starting to think that he has water built up in the filter. If there were water in the trans wouldn't it just shift weird not have a loss of power?
    Bastek likes this.
  2. Apr 17, 2018 at 9:33 AM
    #42
    Dank24
    Dank24 [OP] Well-Known Member
    3rd gen OF
    I’m gonna check this I get home from work. Hopefully the weather cooperates
    Bastek likes this.
  3. Apr 17, 2018 at 9:39 AM
    #43
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    yeah water is a cruel mistress to vehicles
    BillsSR5 and PROseur like this.
  4. Apr 17, 2018 at 11:01 AM
    #44
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Rats? Really, did any damn rats eat the wires?
  5. Apr 17, 2018 at 11:17 AM
    #45
    kmev
    kmev Well-Known Member
    2001, 2017 Tacoma SR5
    Actually, this is exactly what WD40 was made for. The WD stands for "water displacement", and is designed for electrical contacts. It is not designed as a penetrating oil - what everyone actually used it for.
    Wedge, christurnerrr, FLYH2O and 3 others like this.
  6. Apr 17, 2018 at 11:26 AM
    #46
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Exactly, biggest misconception is to use it as lube..it's a de-greaser, so loosen otherwise gunked crude, rust, etc..
    Has anyone tried using Rustoleums NeverWet Hydrophobic spray on coat on or around sensitive areas around their under carriage? Curious if that would help, or create shorts.
    OnHartung'sRoad likes this.
  7. Apr 17, 2018 at 11:27 AM
    #47
    OnHartung'sRoad
    I worked on some water quality measuring equipment that had a sensor with a plug. The manufacturer used shrink tubing filled with a dielectric grease to seal the connectors so they could be lowered over 30m (about 100ft) under saltwater in the ocean. Maybe using a similar grease under self sealing tape mentioned by @Drunken Chewbacca would keep water out of the connectors.
    Wedge and Slashaar like this.
  8. Apr 17, 2018 at 11:28 AM
    #48
    OnHartung'sRoad
    That stuff is crazy cool! Dont know its conductivity though.
    N2DesignsInc[QUOTED] likes this.
  9. Apr 17, 2018 at 11:30 AM
    #49
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I read somewhere the auto trans have a breather on the bottom. Maybe water got in through there? One of the reasons I've heard not to go through water crossings in an A/T.
    lynyrd3 likes this.
  10. Apr 17, 2018 at 11:42 AM
    #50
    N2DesignsInc
    Los Angeles, CA
    So if you want to offroad, you have to mod that or buy a 6MT? What happens if you buy a TRDPRO A/T and have all these offroad features on a $45-$50K truck, you can't use it? Something is not adding up here...why do they market it as offroad? It is expected there will be some puddles as it doesn't specifically say dry terrain only, obviously they don't recommend that you use it as a boat, but still...that's ridiculous (not you), the issue you brought up if true.
  11. Apr 17, 2018 at 12:11 PM
    #51
    coopcooper
    alberta canada
    yeah but it comes out on top of the bell housing. if you could get into water deep enough to submerge it that would be the least of your issues.
  12. Apr 17, 2018 at 12:17 PM
    #52
    lynyrd3
    Bill
    East Central Upstate NY
    Yes there is a breather on the auto trans !
  13. Apr 17, 2018 at 12:22 PM
    #53
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    The air is pulled in from the passenger wheel well. Check the air deflector for a clog. The one on the right is the stock air deflector. The scoop could hold dirt or other things. It goes straight to the air box. Check that next.
    Dank24[OP] likes this.
  14. Apr 17, 2018 at 12:34 PM
    #54
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    scottalot likes this.
  15. Apr 17, 2018 at 12:48 PM
    #55
    Dank24
    3rd gen OF
    iwashmycar and BillsSR5[QUOTED] like this.
  16. Apr 17, 2018 at 12:52 PM
    #56
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    The O.P's truck and all the other Tacoma's should easily be able too ford water he went through,the problem is these new trucks have 100's of sensor's,tons of electric wiring running through the floorboards where even 18 inchs of water can reach, older trucks didn't have all the crap making them better at well,being a truck.
    New trucks simply have too much electrical/plastic junk on them.
  17. Apr 17, 2018 at 1:02 PM
    #57
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I feel like it COULD be more mechanical a problem. If you happened to throw out your alignment enough, it very well may act how you are describing. Its tough to drive wheels that are not aligned right. Just a thought, as I dont know just how low on power it actually feels.
  18. Apr 17, 2018 at 2:16 PM
    #58
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Seriously doubt that. Can you narrow it down on their wesbite of uses for me here https://www.wd40.com/uses-tips
    I sure don't see it.
    WD-40 makes a special type called specialist https://www.wd40specialist.com/products/contact-cleaner/, MADE by WD-40. "Blasts away oil, dirt, flux residue and condensation from sensitive electronics and electrical equipment with pinpoint precision." That is not what was originally discovered in 1953 (WD-40) by a long shot.
    There are countless posts of never to use the regular stuff, I wouldn't even touch it.
    So you are going to "displace" the moisture further into the plug pass the pins where it can't escape now with regular WD-40 without any corrosion protection ?
    You think aerospace/military uses that kind of stuff. Actually they would replace it, but WD-40 as a temporary would be unheard of, actually laughable.
  19. Apr 17, 2018 at 2:27 PM
    #59
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    shakerhood and 2016Tacoman like this.
  20. Apr 17, 2018 at 2:28 PM
    #60
    2016Tacoman
    J
    Lawfarin, shakerhood and BillsSR5 like this.
