Went through water... now issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dank24, Apr 16, 2018.
  1. Apr 18, 2018 at 3:36 PM
    #101
    Tnt tacoma
    Tnt tacoma Member
    I don’t know what the vent looks like on these transmissions but it is not uncommon for damage in shipping and then that could go unnoticed and installed on new equipment. Toyota’s are great but nobody’s perfect all the time
  2. Apr 18, 2018 at 3:44 PM
    #102
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed. Secondary smog pump mod done. Cali Raised ditch lights and amber fog lights installed with On off switches installed in 2 of 3 factory blank slots!
    who makes the best diff breather mod....and does it apply to the front diff also???
  3. Apr 18, 2018 at 3:48 PM
    #103
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Fletcher007[QUOTED] likes this.
  4. Apr 18, 2018 at 4:21 PM
    #104
    Dank24
    Dank24 [OP] Well-Known Member
    3rd gen OF
  5. Apr 18, 2018 at 5:31 PM
    #105
    OnHartung'sRoad
    Great! Buy some stainless zip ties to install it- they make good hose mounting ties when you route it. I didnt drill through the filler, instead I tied the breather tip to the side of the cubby in the fender well.
    Dank24[QUOTED][OP] likes this.
  6. Apr 18, 2018 at 5:37 PM
    #106
    Itchyfeet
    Itchyfeet Well-Known Member
    When someone says they drove through water and now have issues add 8-10 inches to how high they claimed the water was.
    Garrett75x, BillsSR5, tomwil and 4 others like this.
  7. Apr 18, 2018 at 6:20 PM
    #107
    Dank24
    3rd gen OF
    Yeah, that’s not the case here. Max 16-18”
    EatSleepTacos likes this.
  8. Apr 19, 2018 at 3:53 PM
    #108
    Dank24
    3rd gen OF
    So the verdict is grime in the rear diff still. All is well now
    Stew22 and tcjacado like this.
  9. Apr 19, 2018 at 4:03 PM
    #109
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    its fixed?
    shakerhood likes this.
  10. Apr 19, 2018 at 4:17 PM
    #110
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I thought you earlier said disconnecting the battery cured the issue for a short period of time, that sounds more like an electrical issue than dirt in the diff.
    BillsSR5, tcjacado and PROseur like this.
  11. Apr 19, 2018 at 4:25 PM
    #111
    Dank24
    3rd gen OF
    It was prob a placebo effect
    shakerhood[QUOTED] likes this.
  12. Apr 19, 2018 at 4:26 PM
    #112
    Dank24
    3rd gen OF
    Yup, all is good
  13. Apr 19, 2018 at 4:30 PM
    #113
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I knew it wasn’t gonna be an electrical issue. Usually you’ll get a code if somethings electrical is causeing the truck to go in limo mode or hesitate. All the exterior connectors are sealed and even if some dirt got in them it won’t hurt if they were all plugged in before hand. Corrosion wouldn’t happen that fast. It wasn’t sea water he was in. My guess was more along the lines of the rear drums being gunked up though
    Dank24[OP] likes this.
  14. Apr 19, 2018 at 4:31 PM
    #114
    Dank24
    3rd gen OF
    Bought all the stuff today to run an extended breather
  15. Apr 20, 2018 at 5:00 AM
    #115
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Was anything done to fix it?
  16. Apr 20, 2018 at 6:01 AM
    #116
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    At least nobody suggested spraying water displacement WD-40 in the diff ! :amen:
  17. Apr 20, 2018 at 7:10 AM
    #117
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    I did the rear diff mod using a kit from Yota Shop cost about $23 shipped and I installed with zip ties in the taillight area.
    OnHartung'sRoad likes this.
  18. Apr 20, 2018 at 7:13 AM
    #118
    TacoHunter59
    TacoHunter59 Well-Known Member
    Nathan
    Arizona
    2015 DCSB TRD Offroad 4x4
    Ummm....stuff and more stuff
    :rofl::rofl:
    2016Tacoman[QUOTED] likes this.
  19. Apr 20, 2018 at 7:14 AM
    #119
    OnHartung'sRoad
    Replace your plastic zip ties with stainless zip ties and forget about them- I had to do it on my 1st Gen after I saw drooping hoses and wires after the plastic zip ties got old and brittle and started breaking.
  20. Apr 20, 2018 at 8:27 AM
    #120
    JAL
    Mississippi
    Have a link or source for the “stainless”?
