Went thru water , apprx 3 foot, now truck shudders at lower rpms when shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thibs, Aug 23, 2016.
  1. Aug 23, 2016 at 10:39 AM
    thibs
    thibs [OP] Member
    South Louisiana
    2007 tacoma 4x4
    After going thru the water twice, almost immediately after exiting , truck began to shudder when nearing shifting at lower rpm's.
    Isn't that noticeable if acceleration is faster. Also, not too bad when truck is cold. Starter also went out after passing thru water.
    Brought it to a trusted tranny shop and he transmission looked good, ( fluid color no metal , etc). He wasn't sure where it was coming from, suggested drive shaft center bearing but I replaced that last year and it was good prior to water entry. Service engine light not illuminated...... ????
    Any help is appreciated
  2. Aug 23, 2016 at 10:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    How's your air filter look?
    ramonortiz55 likes this.
  3. Aug 23, 2016 at 11:46 AM
    thibs
    thibs [OP] Member
    South Louisiana
    2007 tacoma 4x4
    Looks good I checked that shortly thereafter thinking it had water but it was ok.
  4. Aug 23, 2016 at 11:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did the top of the motor get wet at all? Like the plugs or connections?
    digitaLbraVo likes this.
  5. Aug 23, 2016 at 12:02 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    This as well.
    When did this happen?
  6. Aug 23, 2016 at 12:20 PM
    thibs
    thibs [OP] Member
    South Louisiana
    2007 tacoma 4x4
    This happened Sat Aug 13th. Don't "think" water reached he plugs but not sure. Should have checked those before I posted .......
  7. Aug 23, 2016 at 12:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    You might want to check connections on the transmission also.
    Did you check differential oil also?
  8. Aug 23, 2016 at 12:23 PM
    digitaLbraVo
    Could have corroded some wiring, wet/corroded/shmoo'd the MAF.
    eon_blue likes this.
  9. Aug 23, 2016 at 1:10 PM
    thibs
    thibs [OP] Member
    South Louisiana
    2007 tacoma 4x4
    No I didn't check the differential, just had the tran fluid checked. I will check the MAF as well.
    Thanks for the ideas
  10. Aug 23, 2016 at 1:12 PM
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    check the rear diff fluid and if it's milky/brown, drain it immediately and get some fresh fluid in there. Then do the rear diff breather mod if you havent already.
    Seabass likes this.
  11. Aug 23, 2016 at 1:28 PM
    Clearwater Bill
    Billy
    Largo Florida
  12. Aug 23, 2016 at 2:58 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    With any vehicle that has been submerged, the differential fluid and maybe even the transmission fluid should be changed. It doesn't take much water contamination to ruin things.
  13. Aug 23, 2016 at 3:06 PM
    eon_blue
    Azusa, CA
    +1. The MAF sensor is a fickle bitch, anything so much as looks at it wrong and it'll cause you problems. Usually throws a code though, no? When mine went bad on both my old Prerunner and my current truck I got hit with a CEL.
    Skyway and Taco Addiction like this.
  14. Aug 23, 2016 at 3:18 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I'd let it dry out good... Do these trucks not have a distributor cap?
    Water in the distributor cap used to throw the same symptoms.
  15. Aug 23, 2016 at 3:27 PM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Good luck with it all man, It was crazy over there. Hope you get it figured out!
  16. Aug 23, 2016 at 3:29 PM
    Skyway
    Ande'
    St.Pete
    God bless you and your family Mr. Thibs!
  17. Aug 23, 2016 at 5:58 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    im right in south Louisiana to. hope you and your family are doing well, we were lucky, no water in the house, thank God. I had similar problem. for me it was the coils on cylinders 5 and 6. the seals let water in. if you pull the coils, look to see if it looks like water was there then dried up. it took a few days, it got rougher and rougher, then misfires started. I replaced coils and plugs, good as new! if you get any dash lights come on I keep an OBD diag scanner in my truck 24/7 if your nearby let me know. hollar if you need something brother :)
  18. Aug 23, 2016 at 6:01 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    [Qfor sure check different oil. UOTE="Taco Pete626, post: 13073047, member: 94116"]With any vehicle that has been submerged, the differential fluid and maybe even the transmission fluid should be changed. It doesn't take much water contamination to ruin things.[/QUOTE]
    for sure check diff oil. pull the fill plug, you can tell right away if water got in.
  19. Aug 23, 2016 at 8:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No. Not for a very loooong time.
    Skyway[QUOTED] likes this.
  20. Aug 23, 2016 at 10:49 PM
    kastilyo
    kastilyo Well-Known Member
    San Ramon
    2024 Double Cab White TRD Off Road
    Bad ignition coil, coz of the water, at high speed not noticeable...
