Went to Halogen to LED headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldtacoma2002, Apr 10, 2025.
  1. Apr 10, 2025 at 4:40 AM
    goldtacoma2002
    goldtacoma2002 [OP] Member
    Good morning everyone, I just purchased some LED headlights from Ebay and installed them in my 2002 Tacoma. My question is that when I turn on my brights they don't switch and come on. I switched back to the halogen ones to see if I blew a fuse and everything worked with the halogen lights. Do I need to rewired something or is there some sort of adapter I need to purchase to get the high beams to work.
    Also here is the lights I purchased.
    https://www.ebay.com/itm/185945377131?itmmeta=01JRFQNPNQKHV7E7K8QF94YEST
    Thanks.
  2. Apr 10, 2025 at 8:06 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Those LED bulbs are garbage. Any of them. Not only dont they ever function good but theres not cut off on them and they are annoying bright. Do a retro fit on the housings and slap some projectors with some good bulbs and call it a day. Better lighting and better looking that these LED bulbs. They are just not made or meant for our trucks.
  3. Apr 10, 2025 at 8:21 AM
    02hilux
    Planet: EARTH
    Honestly, HID/LED are not meant for halogen housing unless you got projector lens.
    I love my LP9s when folks drive with their mix match blinding headlight.
  4. Apr 10, 2025 at 8:46 AM
    goldtacoma2002
    We did switch out the original housings with clear lenses would that fix them. I am seeing that maybe those lights are garbage. Can you send me a link of what type of projector lens you used.
  5. Apr 10, 2025 at 8:47 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Please don’t run LEDs in a halogen housing. All you’re doing is blinding oncoming drivers.
