Were they doing this right?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myname150, Feb 25, 2012.
  1. Feb 26, 2012 at 11:22 AM
    jimalan1989
    jimalan1989 Member
    Jimmy
    Columbus, MS
    2011 4x4 Double Cab Long Bed SR5
    NONE
    if you look close enought the larger pad is actually contacting the trucks frame rails, yes the rubber blocks are contacting the pinch wells but the rub blocks dont appear to be to actaully be supporting that much weight there not squished at all. the mechanic may have just put them there to cover his ass if the truck was to shift on the lift. im not saying i would lift a truck on that style lift im just calling what i see
  2. Feb 26, 2012 at 11:26 AM
    Ccwahoo
    Ccwahoo "Get comfortable being uncomfortable" Goggins
    Central Virginia
    '10 TRD Sport 4x4
    They must have spotted your Obama bumper sticker :laugh: only kidding of course
  3. Feb 26, 2012 at 11:30 AM
    way2fast
    way2fast Well-Known Member
    Ethan
    Wichita Falls, TX
    07 DC TRD Sport SR5 PreRunner
    2.5 King resi c.o., 2.0 fox piggys, deaver j66s, bhlm, grillcraft,
    i used to work at a discount tire and no they aren't doing it correctly if they can lift it by the frame with the lift. If not we were supposed to use a flat bay and jacks. But on car and vans we would use the rubber blocks on the pinch welds like they seemed to have done. Shouldn't hurt it but it wasn't correct.
  4. Feb 26, 2012 at 11:33 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Looks like the frame is raised in the front by those blocks due to the gap - you can see the other tire. The rear seems to be resting on the frame and not on the blocks. I'd totally ask for a discount on ... anything.
  5. Feb 26, 2012 at 11:43 AM
    way2fast
    Ethan
    Wichita Falls, TX
    They should have put the blocks under the frame to that it was level front and back and not resting on the front crossmember. There are dumbasses no matter where you go just depends on the peoples attitudes that are working if they care or not. I personally saw someone jack up a superduty by the oil pan :smack: and it was one of our newer managers. :facepalm:
  6. Feb 26, 2012 at 12:44 PM
    myname150
    myname150 [OP] Well-Known Member
    They did have a jack, it was propping up the rear axle and the jack was located under the rear differential.
    And that's what i'm saying, why would the blocks be needed? Lifting the frame it's self would be better, and safer wouldn't it?
  7. Feb 26, 2012 at 12:52 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Yep!
  8. Feb 26, 2012 at 1:01 PM
    millerm20
    millerm20 Member
    mark miller
    charlotte NC
    08 sr5
    it needs to be lifted by the frame,and they should not be using wood
  9. Feb 26, 2012 at 4:38 PM
    way2fast
    Ethan
    Wichita Falls, TX
    Yea they should have used the frame but sometimes we would have to go ahead and do ths axle also like you said
  10. Feb 26, 2012 at 5:51 PM
    myname150
    Cool.
    I'm not like extremely mad at them for this, we're all human and we all make mistakes...if I do see it again, then I will have a word with them because I know it's no good for the cab mounts.
  11. Feb 26, 2012 at 6:04 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Yep, that's an Obama supporter.
  12. Feb 26, 2012 at 6:15 PM
    Ccwahoo
    Central Virginia
    '10 TRD Sport 4x4
    :laugh: :rofl:
  13. Feb 26, 2012 at 6:20 PM
    myname150
    Yes Sir! :D
  14. Feb 27, 2012 at 4:09 AM
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    Which location in Houston did this occur at?
  15. Feb 27, 2012 at 5:38 AM
    #35
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    just because they are "nice" people, doesn't mean they are smart. take the truck elsewhere next time, where they have a real lift.
