Westcott Designs - TRD Sport Preload Collar Lift Kit
Discussion in 'Suspension' started by Omegastu, Nov 5, 2022.
  1. Nov 5, 2022 at 7:35 PM
    Omegastu
    Omegastu [OP] Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
    908tacoma likes this.
  2. Nov 6, 2022 at 6:13 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    westcott is a good company and they finally released a version of the collar lift for the sport. Problem is, the stock hitachis. They are garbage
  3. Nov 6, 2022 at 6:22 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Go with the Billy’s. Have (pay), the vendor to setup the spring/coil.
  4. Nov 6, 2022 at 11:16 AM
    Omegastu
    Mid Tenn
    It states you get a 3 inch lift without new UCAs..... How does that work?
  5. Nov 6, 2022 at 1:42 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    the lift is achieved by putting more tension on the spring. The use of uca’s doesn’t affect the lift height. The problem of going that high without uca’s is an unfavorable alignment. You lose caster when lifting the truck and the stock suspension isn’t designed to get enough caster once lifted.
  6. Nov 7, 2022 at 9:47 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Lift height wont guarantee tire fitment, so don't bank on fitting 285/70/17 tires without issues. If you really get 3" of lift with this, I would have a lot of questions in regards to shock position at ride height compared to the overall shock travel. Better than a top hat spacer lift, but only expect added lift for looks only.
    Detailed tech article on this subject coming soon!
    908tacoma, Omegastu[OP] and a2lowvw like this.
  7. Nov 8, 2022 at 9:36 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Its basically a spacer lift, Makes sense for the OEM Fox 2.5. But for the price its not worth it for the stock shocks on our trucks. I wouldn't buy into not needing UCA's after their 3" lift either. Caster numbers will be very low and the vehicle will wander around.
  8. Aug 22, 2023 at 8:06 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    So I've been hearing a lot people talking about adding this lift to their TRD Pro's... But how exactly does that work with the Fox internal bypass shocks? According to Toyota, the Tacoma's have 8 bypass zones in the front and and 11 in the rear. That's about 1 zone per inch of travel. Westcott advertises 1.5" lift in the front and 1" in the rear. Wouldn't these lifts put the ride height out of the "Ride Zone" that the shocks have been designed for then?
    I'd be curious to hear if anyone knows the specifics of how this affects how the shocks perform.
    AccuTune Offroad likes this.
  9. Aug 22, 2023 at 8:23 AM
    AccuTune Offroad
    El Cajon, CA
    Your thinking is correct. I wish I had specs on their IBP to help confirm.
    https://accutuneoffroad.com/spacer-lift-vs-preload-spacer-vs-coilover-preload/
    a2lowvw and Saskabush[QUOTED] like this.
  10. Aug 22, 2023 at 9:25 AM
    Saskabush
    Adam
    2013 TRD Sport
