Westcott vs Peak suspension collar lift kits
Discussion in '4th Gen. Tacomas (2024+)' started by KABO, Jun 27, 2024.
  1. Jun 27, 2024 at 10:49 AM
    KABO
    KABO [OP] Member
    Northern CA
    2024 TRD Off Road
    The westcott preload collar lift kit (2.5" in front 0.75" in rear) is one piece for the front and a rear spacer. The peak suspension 2-pc trail lift kit (2.25" in front and 1" in rear) is 2 pieces for the front shock and a rear spacer. Question: is there a difference between the two other than peak suspension having an extra piece for the front shock? Obviously one is preload and the other splits up the load. But any noticeable performance difference. Just curious as to why they decided to do it differently.
  2. Jun 27, 2024 at 10:51 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    I bought the peak, it looks like a solid kit, someone mentioned the threads on the top hat are a bit sketch or short for engagement, but most seem happy with it and I know Peak chimed in and said it was fine / normal. Would have kept it but gonna do King setup instead.
    KABO[QUOTED][OP] likes this.
  3. Jun 27, 2024 at 11:03 AM
    KABO
    KABO [OP] Member
    Northern CA
    2024 TRD Off Road
    Yeah I saw that thread about the concern with not enough thread on the top with the top spacer. Good to know Peak chimed in and said it was fine. The shop I went with didn't carry the Peak lift, they had the Ready lift if I wanted a 2-pc kit
  4. Jun 27, 2024 at 11:04 AM
    TacoBuffet
    AL
    Think the ready lift is just a straight spacer, seen that be the dealer norm.
